| Chip Amps Amplifiers based on integrated circuits |
I want to build a stereo amp that can output between 80-100W per channel into 8 Ohms. I have been looking around, and chipamp.com's kits look like a good place to start, however, I don't know which kit to purchase. Will I need to parallel output to get the power I am looking for?
Thanks in advance for the help, Scott |
#2 |
The LM 4780
left lane is for passing, slower traffic keep right please. |
#3 |
Bump: Can anyone give me some information about paralleling or bridging the amps to get the power I am looking for? Also, how many transformers will be required?
#4 |
Bump: Anyone?
#5 | |
#6 |
Hi Scott, Jeff's prolly right, there are lots of discussions going on about the differences between these chips and kits. Not the least of which is the CarlosFM Snubberization that's being implimented with the new ones.
If you need the most power, or want to drive 4 Ohm speakers w/o the snub, the 4780 is it. It's essentially two 3886's on one chip, but it needs a larger heatsink. OTOH, the 3785 is more documented at the moment, and is slightly easier to build if it's your first one as the pictures in Brian's manual presently show it's construction. This'll get you up to around 56W. There's lots to read here, and you will, but jump right in. The kits make it easy, Read the sheets at National to get a complete overview of the basic IC's. One hint to the search function here is to click the "Show results as posts" button. Why do you need 80-100 WPC? (rhetorical question, but feel free to answer)
onasis |
#7 |
The speakers I currently have (some cheap-ish Sony towers) have an program rating of 120 or thereabouts, and I want to be able to drive them to their potential.
56W might be loud enough though. Can you get 56 Watts out of the stereo kit, or is that the dual mono? Thanks for your help. |
#8 |
I'm sure one of these will drive them to their potential. To me, 2 Watts to most speakers is around 90dB and that's quite loud.
You should also look around Nick's Decibel Dungeon . most everything you'll need to know that isn't on Brian's site is spelled out rather well.
onasis |
#9 |
| BrianGT chipamp.com dual mono lm3886 amp | valleyman | Swap Meet | 8 | 21st October 2008 11:43 AM |
| Problems with Chipamp (LM3886) BrianGT | Puffin | Chip Amps | 44 | 17th October 2008 12:47 PM |
| umbilical for BrianGT kit | waltona | Chip Amps | 11 | 26th April 2005 07:00 PM |
| Transformer and pot for BrianGT kit | poeee | Chip Amps | 15 | 28th November 2004 01:49 AM |
| BrianGT? | rafalc | Chip Amps | 6 | 8th August 2004 08:16 PM |
| Page generated in 0.10217 seconds (78.18% PHP - 21.82% MySQL) with 10 queries |
