Old 21st February 2005, 06:47 PM   #1
velikan is offline velikan  Croatia
Default Strange noise form lm3875
It all looked to good to be true. :-(
I assemblied new lm3875 board, listen it for a some time and then something strange happend to sound from one speaker. Yes, before that i volumed up the music and then sound become distorted and stay like that. I can't realy describe that sound. It has high freq and it is similar to the sound from radio station when it is tuned. It can be played loud and every segment of sound (low, middle, high) is infected.
Other channel is OK.
What could it be?
Old 21st February 2005, 06:57 PM   #2
This amp is probably oscilating. Control again all connections and devices.
Old 1st March 2005, 05:45 PM   #3
Well, i finaly found some time to examine the problem.
Now things aren't as i said before. I CAN connect noise with volume control or with bass witch is producing most of it.
I examined all elements and noticed some strange black fluid on pin 4 (neg pole). Does anyone know something about it?
Then I tried to measure the resistance between pin 4 and lm chassis and that connection wasn't shorted.
As I said in my first post, this happened when i turned the volume up to the limit.
I have non-inverted version with 22k/680 gain and 2x20 Vac secondaries.
What is the problem? Me or LM?
Strange noise...? Skorpio Solid State 16 6th August 2007 07:21 AM
Strange noise coming from MTX Thunder1004 amplifier fastblackcar94 Car Audio 1 17th November 2006 10:17 PM
A strange problem with bridged LM3875 Mrpong Chip Amps 28 13th September 2006 04:46 AM
strange noise from right channel keyser Everything Else 15 2nd May 2005 11:14 PM
About strange noise from my amp! Otherwise Solid State 6 11th September 2003 01:12 PM
Page generated in 0.06401 seconds (71.81% PHP - 28.19% MySQL) with 10 queries
