| Chip Amps Amplifiers based on integrated circuits |
#31 | |
The problem is my signal could be coming from my soundcard, PS2, VCR ,etc... So I would be assuming they all have a low output impedance. Is this safe to assume? Without the first buffers my circuit would look like this: Will this work? edit: i notice R8 will have to be changed to from 3k3 to 10k now, not that it makes much difference |
#32 |
I'm gonna need a preamp for a volume control if I want to hook up anything but the computer directly. My apologies,I was getting ahead of myself.
So I can build the circuit without the input buffers to hook up to my computer and if that doesn't work I will use a preamp with a volume control as a buffer because I'm gonna have to build this simple preamp for other inputs anyway. I really wish I had a receiver with preouts... |
#33 | |
Banned
Make one : O ) it's simple message me ill show you. : O ) |
#34 | |
My intention was for this to be a temporary fix until I get a good reciever with a better built-in crossover. (Then I'll have the problem of a 4th order acoustical HP with only a 2nd order LP but I still wont be able to use this circuit because I'll need the front channels to be powered by the receiver and the DAC too.)
If you mean make a DIY HT amp, I would like to but it's just cheaper to buy and guaranteed to work as a bonus! I haven't even looked at how to build a DAC as the whole idea sounds scary to me. |
#35 |
I couldn't wait so I built a Linkwitz transform on a breadboard. And it actually worked right away! I get a small 60hz buzz but not much.
It seems like the subs are gonna reach Xmax before the mains... I may not even need a HP for the mains. I am glad I didn't get a 250W plate amp like I had considered because I got the clip indicator to flash on my 370W amp and the subs could still take more. I may have to change the wiring for 2 ohm rather than 8 ohm. Its just damned hard to get under 25hz with any amount of SPL. edit: I gonna have to try better positioning for the subs....Walking around the room reveals how much I can achieve. Every little knicknack throughout the house vibrates even way at the other end of the house. |
| I need an active sub filter! | hernanstafe | Subwoofers | 18 | 4th December 2007 09:32 PM |
| active filter from rod elliot and sub filter questions | wuffer | Parts | 0 | 2nd October 2005 01:12 PM |
| Active Filter | ChevS-10 | Solid State | 4 | 24th June 2005 05:35 PM |
| active filter | k1jroth | Chip Amps | 50 | 1st December 2004 04:15 PM |
| looking for active filter sim | P.Lacombe | Everything Else | 0 | 2nd January 2003 09:33 PM |
| Page generated in 0.13150 seconds (56.59% PHP - 43.41% MySQL) with 11 queries |
