| Chip Amps Amplifiers based on integrated circuits |
Ok my GT kit doesn't want to work
First time I switched V- and V+ accidentally so they blew then I switched both V- and V+, checked resistance between chip and heatsink: no problem there. But when I turn the power on both secondary fuses (3A) blow and a little blue smoke appears from the pcb any advice? |
#2 |
put the blue smoke back in?
reverse the caps?
Two little mice fell in a bucket of cream. The first mouse quickly gave up and drowned. The second mouse, wouldn't quit. He struggled so hard that eventually he churned that cream into butter and crawled out. |
#3 |
I am sure you blew up more than just the chips. Check the other components like the rectifiers and capacitors. You can't blame Brian because you swapped the positive and negative supplies.
----------------------------------------------- Kilowattski |
#4 |
You have to replace rectifiers.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#5 |
I'm not blaming brian, I just want to get my amp working.
PSU is in separate housing and working fine. C's mounted correctly (V-: negative lead,PG-: positive lead, V+: positive lead, PG+: negative lead) Is there a way of checking without turning the power on? |
#6 |
Capacitance meter...
Twisted Pear Audio |
#7 |
i second that replace all the rectifiers. and look the pcb over
make sure there are no fried traces i got a few kits and i fried one rectifier pcb. i put the rectifiers backwards buzzz pop
#8 | |
Sounds like you have a short somewhere. Check all your leads and solderings very carefully, there is a fault in there.The fault is still there when the fuse blows It can be a little thing like a stray strand on one of your leads. Or a solderbridge. Compare everything closely to Brians nice building instruction. Component orientation and so on. It could also be your solderiron that accidentaly meltet something it wasn't supposed to. Good luck. Steen. |
#9 |
I found my mistake: somehow V+ is connected to V- on the pcb.
I haven't found a solution yet, no visual solderbridges. but I noticed that heat conducting paste got between the legs of the chip. that shouldn't be a problem right? |
#10 | |
| BrianGT PS PCB layout | dsavitsk | Chip Amps | 1 | 19th June 2005 01:17 AM |
| umbilical for BrianGT kit | waltona | Chip Amps | 11 | 26th April 2005 07:00 PM |
| blowing fuses | homegrown45167 | Car Audio | 2 | 22nd October 2004 01:16 PM |
| BrianGT? | rafalc | Chip Amps | 6 | 8th August 2004 08:16 PM |
| blowing up my amp | lilnigg99 | Multi-Way | 1 | 13th August 2003 11:38 PM |
| Page generated in 0.14512 seconds (54.73% PHP - 45.27% MySQL) with 10 queries |
