| Chip Amps Amplifiers based on integrated circuits |
Hy.
I didn't think of it when i bought yesterday my toroid but here is the problem: how to put two lm338 voltage regulator on psu with one rectifier bridge??? My trafo don't have two separate windigns but star point. I am afraid that i will make closed loop with two rectifier bridge |
#2 |
To my knowledge its not possible to use this Pedja lm338 circuit with only one bridge.
You should use an other kind of regulator circuit. Or an other toroid.
Music is what i want, music is what i need |
#3 |
ebijma is correct; in order to use two positive regulators (e.g. two LM338's) you need two completely isolated supplies, and that means either a dual-secondary transformer (not a centre-tapped one) or two transformers, and a bridge rectifier for each. If you have a centre-tapped transformer and/or only one bridge, then you need to use a negative regulator for the negative rail, since the supplies share the common ground point.
#4 |
Yes, i thinked so.
Luckly, i managed to separate the star point. Thank you P.S. What people says for Carlos Filipe capacitor inductance compensation. I am using some capacitance after regulator. |
#5 |
I'm not sure what you are powering off of this but you could resort to LM317/LM337 split regulated supply. This won't handle 5 amps like an LM338, but it will handle 1.5. This is likely enough for one channel of LM3875/LM3886 but you would be pushing it with 2 channels.
If you take something apart and put it back together again enough times, eventually you will have two of them. |
| 3 Pin regulated supply VS zener based supply | KevinLee | Solid State | 3 | 15th September 2008 03:40 PM |
| How to do Single center tap/bridge regulated supplies? | ChuckT | Chip Amps | 10 | 14th February 2008 03:23 PM |
| regulated supply +- 28V -20A | sss | Power Supplies | 8 | 14th June 2005 08:30 AM |
| regulated supply for GC | yuval | Chip Amps | 9 | 16th April 2004 10:06 AM |
| regulated 5V DC supply | Tomatito | Tubes / Valves | 50 | 4th February 2003 09:33 PM |
| Page generated in 0.08866 seconds (69.54% PHP - 30.46% MySQL) with 10 queries |
