Old 7th July 2005, 10:16 PM   #831
Banned
Originally posted by motherone
Well, they stick 4 of them on per channel (left/right/ground) and go with that. But for a preamp, shouldn't 100ma be plenty? Plus that buffer has some pretty great specs.. It's just food for thought.
I would avoid to parallel buffers.
Yes, for a pre 100ma is plenty.
I agree that the THS4082 is impressive as well. They keep putting stuff out faster than people can update/design around.. At least in the DIY community
I edited my post, either the 4082 and the 4062 are very good choices, sound good, and that's what I've been using to change those junk they put on the headphone outputs on CDPs, etc.
Old 7th July 2005, 10:29 PM   #832
Yup.. At this point, the "latest" designs are basically using discrete diamond buffers or class-a output stage with an opamp for gain. At some point, it will probably return to being all-discrete designs
Yes, but with their specs, they're probably not drop-in replacements for standard opamps without careful considerations on bypassing (gasp! ) and HF performance.
Anyhow, my suggestion was mainly so you could build a nice pre using some other IC based buffers that may offer superior performance to the BUF634. Not to say it's a bad chip, it's just that one of those Intersils might be better at this application.
Old 7th July 2005, 10:50 PM   #833
Banned
Of course, man.
I never just drop-in an op-amp...
Old 8th July 2005, 07:28 PM   #834
steenoe is offline steenoe  Denmark
steenoe's Avatar
Is anyone interested in this design?
I might be!
Then again, I could just etch my own The design is pretty interesting, as the BUF is exspendable in most systems.
Why bother to use a buffer when it only has 100ma output current?
Excactly right! Why bother with an extra component in the signal path, when it is not needed??
Steen
Old 8th July 2005, 10:50 PM   #835
n00beR is offline n00beR  United Kingdom
Send a message via MSN to n00beR
Has anyone done any fully discreet designs, I would most certainly be interested in one of those
* beavers away in eagle! "oooooh this thing only has three legs" *
::bleh::
Old 10th July 2005, 12:24 AM   #836
Russ White's Avatar
Send a message via Yahoo to Russ White
I posted my latest design in a new thread here:
freebird
Since it focuses on a non-buffered solution.
Cheers!
Less pulp more juice Twisted Pear Audio.
preamp layout suggestions please gary h Tubes / Valves 4 6th October 2008 12:20 AM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 09:57 PM
Two preamp swithceroo. Suggestions? fazman Solid State 1 15th February 2007 10:37 PM
Preamp suggestions r0cket- Solid State 1 23rd September 2003 02:05 PM
Page generated in 0.10379 seconds (72.73% PHP - 27.27% MySQL) with 11 queries
