| Chip Amps Amplifiers based on integrated circuits |
#101 |
As promised here are the eagle board files for the the PMA preamp I have been working on. I have also included the voltage regulator boards. I haven't yet had a chance to label everyting on these boards, feel free to do it and psot them again. You will notice that I made a few changes here and there. Mostly I moved the output so the traces were shorter, added pads for larger capacitors near the OPA's and also added pads for some caps near the input. I also removed the GND input near the DS1802...it was unnecessary and could have caused a ground loop.
I would like it if somone could help me modify the PSU boards to add a discrete regulator as Steeno suggested. I was looking at some designs last night for this...Pedja Rogic has a nice one on his web site...Alcaids is also very nice. Anyway Enjoy!
If you take something apart and put it back together again enough times, eventually you will have two of them. |
#102 |
Ok, how about this for a supply regulator. The LM3XX's provide 20V to the discrete regulator which uses 15V zeners and MG3055/2955 transistors to bring the voltage down to +/-15V.
Should I put some caps on the output????
#103 | |
If it's a zener + emitter follower the output impedance decrease with increasing value of output capacitance, so yes you need a output cap. |
#104 | |
Banned
This schematic is wrong : O ) The buf 634 sybol is wrong leading it with the pin's wrong also. |
#105 | |
You are absolutely correct...well sort of. I'm working now on finishing up soldering some LM4780 boards so I likely won't be correcting this today...but likely tomorrow.
#106 |
Banned
send me the sch file ill fix it for ya : O ) I was extreamly confused when i was looking at your board and then yuor schematic : O ) then i got it Its de wrong one HEHE. Just wanted to help that's all..
J' |
#107 |
Not sure if it's important to you or not, but I think the TO220 version of the BUF634 has better heat dissipation than the DIP-8 version, plus you could throw a heatsink on for better cooling if you like.
#108 |
I can't find a datasheet for the mg2955/3055 - can someone pls provide a link?
Do these differ from MJE2955/3055? Thx! I'm intrigued by this PS design... ![]() edit - never mind! The board pic lists MJE2955/3055.... |
#109 |
No dual discrete bridge rectifiers?! I mean, c'mon. Everyone does those nowadays
I mean, how audiophile can you get if you're not forced to get a transformer with dual secondaries?! Huh?! Just kidding. It might be smaller/spiffier if you could make each +/- voltage on a smaller, separate board. That way you have a flexible design (like the digi01 boards) that can be used for more stuff! (I'm being selfish here, 'cause I'm thinking about a way to replace my +/- 15v and +5v PSUs on my DAC) |
#110 | |
| preamp layout suggestions please | gary h | Tubes / Valves | 4 | 6th October 2008 12:20 AM |
| twisted pear Preamp/other suggestions for Preamp kit | LukeDuke | Chip Amps | 1 | 1st February 2008 09:57 PM |
| Two preamp swithceroo. Suggestions? | fazman | Solid State | 1 | 15th February 2007 10:37 PM |
| Preamp suggestions | r0cket- | Solid State | 1 | 23rd September 2003 02:05 PM |
| Page generated in 0.98805 seconds (9.98% PHP - 90.02% MySQL) with 11 queries |
