| Chip Amps Amplifiers based on integrated circuits |
Is it feasable to make a "BPA 400" using 4x lm4780 -- 4 elements in parallel bridged with another 4 elements using between a +-30 and 38V swing... not sure If I'd want stability into 2 ohms or not yet... Regardless is there a better chip alternative to the lm4780 for higher power apps?
Thanks, Dylan
Well seeing that I have posted somthing, I am not lurking anymore am I?
#2 |
2 possible issues (asides from the complexity wiring this thing p2p) I am not too sure about while going ahead with this -- Very low input impedance due to 8 ICs as well as possible increase in distortion due to 4 slaves in parallel? How significant would the increased distortion be? Any way to go about calculating this?
Thanks Dylan
#3 |
THe idea is feasable.
To calculate the power disapations you can download some of the excel spread sheets posted on this board. In a nut shell there will be heated areas under the LM4780 chips that you will be hard pressed to get rid of. It will make for an amp itching to die. A better solution will be to use multiple LM3886 chips and spread them evenly over a large enough heat sink. As for the low input impedance you may construct a buffer as per the BPA200 design. There are some thoughts. Mark
Mark |
#4 |
At some point, doesn't it make sense to go to stay at some reasonable power level with one or a few chips, and then do one amp per driver and multiple drivers?
R.G. |
#5 | |
I found when I built a bridged LM4780 amp that it was necessary to make a little clamp/bracket to fasten the chip onto the heatsink. But you can drive it to a full 120 watts with some forced cooling and a clamp. Using machine screws to keep the chip in place isn't satisfactory. |
#6 |
I have to agree that a LM4780 is a dual LM 3886.
That's not news to me. The point I was trying to make that a heat sink works more effectively thus cooling better if it is warmed in more than two hot spots. The use of eight LM3886's will spread the heat over a much larger area and therefore give you a better chance of creating an amp that won't be shut down by the SOA protection inherent in the design of the chips. Granted point to point wiring will be a real headache I still have to make one of these beasts. I have paper designs and have crunched the numbers for almost three years. Not enough time MArk
Mark |
| Favorite Threads and Posts in "Chip Amps" | Variac | Chip Amps | 7 | 28th January 2011 11:13 PM |
| Chip amps used in "push pull" | ChrisA | Chip Amps | 22 | 2nd July 2009 10:18 PM |
| Do we really need high priced "audio grade" power resistors? | panson_hk | Parts | 2 | 23rd April 2009 12:11 PM |
| High Voltage Power Supply PCB "oopsie" Sale | Geek | Swap Meet | 1 | 2nd January 2009 06:06 AM |
| ANY "High-Perf" SIL op-amps to replace NJM5532 | homemade | Parts | 2 | 13th December 2006 04:41 AM |
| Page generated in 0.10377 seconds (80.93% PHP - 19.07% MySQL) with 10 queries |
