Old 17th February 2005, 05:18 PM   #11
ejn327 is offline ejn327  United States
2 amps in parallel share a rectifier and transformer.
How do I measure DC offset? I see it mentioned frequently on the forum here, but don't know how to measure it.
If I can, i will measure the amps and match the closest ones together.
Old 17th February 2005, 05:30 PM   #12
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
You measure DC offset between Output and Ground (meter set to DC volts). You can do it either on the PCB or binding posts (to the speaker). Check this offset at your usual listening volume. If pot is istalled directly at amps input, use max pot setting.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 17th February 2005, 06:59 PM   #13
I can mail you out some of the new resistors (the ones from thecurrent kits), and you can try matching them more closely.
Are these the 1K ohm input resistors? I have access to some 1% that I should be able to get a hold of.
Old 17th February 2005, 08:27 PM   #14
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
I can mail you a full resistor set for all 4 channels if you want.
per channel:
4 - 22k
2 - 680ohm
2 - 1k
Drop me a mail and we can discuss this.
Brian
Old 17th February 2005, 08:42 PM   #15
Thanks for the offer Brian. I got have some 1% 1K resistors today that I am going to try tonight. I also want to measure the DC offset of each amps and match them together as best as I can. I'll let you know how it turns out.
Old 18th February 2005, 01:18 AM   #16
I measured the DC offset of all the chips, and one channel has 170 mV and 90 mV while the other channel has 35 mV and 45 mV.
I haven't had a chance to hook up the 1% input resistors yet, but could that be causing the wide range in offset?
Old 18th February 2005, 01:29 AM   #17
While you were meausering the offset, how the inputs of the individual channels were connected to?
www.audiosector.com
Old 18th February 2005, 02:35 AM   #18
I had the amps hooked up to a portable CD player. The signal to the amp is running through regular wire for now and soldered to some female RCA connectors.
I'm sure that shielded coax would be best for the signal, and I will change it before I hook it up for good.
When I played a signal to the amps, I made sure to keep the output level the same when I checked the offset. I checked them one channel at a time at first and the hooked both up. I got pretty much the same measurements both times.
I also unhooked the output resistors while checking everything
Old 18th February 2005, 02:46 AM   #19
The reason I asked, is because when measuring DC offset, one has to make sure that no DC is also present at the input, otherwise the DC readings at the output might not be right. If your CD player has a DC blocking cap, everything is fine, but just to make sure, can you also measure what value of DC you are getting at amp's input (after RCA jack).
Since you did measure all channels from the same source, there is still substantial difference between the readings, and in case there is no DC passed from your source, 170mV is definitely out of ordinary and you have to replace the chip.
I measured at least 200 chips, and only once I encountered 170mV at the output (with 22k input impedance). The DC values of 120mV you can encounter occasionally (and more often with recent batch of chips), but on average it rarely gets past 70mV (with 22k input impedance; with lower impedances DC also goes down).
www.audiosector.com
One more finished BrianGT 3875 ejn327 Chip Amps 4 3rd March 2005 12:47 AM
LED for BrianGT 3875 Kit dsavitsk Chip Amps 4 27th February 2005 05:35 PM
BrianGT 3875 parts changes dsavitsk Chip Amps 3 25th February 2005 01:34 PM
Noob ? BrianGT Lm 3875 with 10k pot? bender460 Chip Amps 13 12th November 2004 06:14 PM
Two more for troubleshooting BrianGT GC kneadle Chip Amps 13 11th November 2004 06:46 PM
Page generated in 0.14571 seconds (60.00% PHP - 40.00% MySQL) with 10 queries
