| Chip Amps Amplifiers based on integrated circuits |
Hi all, I am new here and have hit the end of my limited electronics knowledge with my new 3875 GC I just built. I made my own PCB's based primarily on Monster's regulated GC.
I picked a nice little transformer at a surplus store here in town that measures 32-0-0-32 and almost matchs a Plitron 160VA single primary model. But I suspect now that it is not 160VA in fact I'd be suprised if it was 100VA given how badly it clips. I have +/-30V DC from the power supply with LT1083's as the regulators, 10000uF on the PS and 1000uF FC caps on the amp itself. I always hear people say that clipping occurs in the treble but in my case it distinctly clicks with bass heavy sections (in the bass of course) at anything more than low volumes. How much current would I need at 30V into 8 ohms? The only other suspect is that my Pinoneer DV-434 has 1.1mV DC offset, but I am using a 4.7uF input filter and 1.1mV isn't enough to offset my input signal so badly is it? In fact now that I am writting this down my Yamaha amp shuts down at higher volumes with audio from my DV-434 too but the cable box doesn't cause this issue. I have tried adding 6.8uF in series with the output of the DVD player into the Yamaha and I can turn the volume up higher before it shuts down but still bass will cause it to shut down... OK so the new question is what is wrong with my DVD player and how can I fix it? is it the DC and how do I fix this offset? |
#2 | |
Let's calculate: 30Vpeak = ~21.2Vrms. Into 8 ohm it generates ~2.65A rms current. 1.1mV is negligible and the input cap will take care of it. |
#3 |
Minor update, I spoke to a Pioneer service center and they say the DC is a bad thing. I also screwed up the model # it a DV-443 (slim line, crap it seems).
Whats a good replacement as an audio source and DVD that doesn't need tweaking to sound reasonable? |
#4 |
And again one more thing, the negative regulator in the PS seems to be getting way warmer with minimal load than the positive side. Is this normal?
#5 | |
audio projects |
#6 |
Well it's all moot now, I blew it up
My unregulated DC was 45V per winding, does phase come into play if I am using 2 completely seperate regulator boards? |
| Need help with powersupply. | Cyberzim | Power Supplies | 33 | 6th August 2009 07:28 PM |
| Powersupply questions | ljk11 | Solid State | 1 | 1st February 2008 01:33 AM |
| DIY Powersupply for UCD | nilsomat | Class D | 9 | 16th November 2006 10:12 AM |
| help with Powersupply | iceman | Solid State | 20 | 7th June 2003 07:06 PM |
| Page generated in 0.10302 seconds (77.31% PHP - 22.69% MySQL) with 10 queries |
