| Chip Amps Amplifiers based on integrated circuits |
Sch
#2 |
size: 2.12 *1.30 inch2
#3 |
top silkscreen
#4 |
the PCB was drawn with PADS2004. If need, i will post the pcb file.
#5 |
Ki, Yep if possible post the PCad files.
Thanks |
#6 |
Sorry, the PADS files
Thanks |
#7 |
here the pcb file.
#8 |
i haven't built this exact pcb, but one of similar dimensions:
1.2" by 2.2". i found from my board: 1.) mounting holes are not needed 2.) you probably will need to mount the capacitors last as they will likely sit very close to the IC's mounting holes. and it may become impossible to secure the IC once the caps are in place. this may mean the amp will be permanently mounted to a heatsink. 3.) pads were small. the wires ended up soldered to the metal surfaces. my design used vertical mounted through hole resistros and wider 1000uF capacitors. this design's taller? capacitors may be fine.
if only it could be used for good, not evil... |
| LM4780 pcb layout and others | BrianGT | Chip Amps | 263 | 13th January 2008 12:26 AM |
| Brian GT's LM4780 PCB layout | D_GR8_1 | Chip Amps | 17 | 4th March 2005 05:37 AM |
| Page generated in 0.07666 seconds (75.57% PHP - 24.43% MySQL) with 11 queries |
