| Chip Amps Amplifiers based on integrated circuits |
Nelson Pass's F1 amplifier got me to begin exploring current amps which lead me to variable impedance which lead me to realize I obviously don't get some basics.
I was looking at http://sound.westhost.com/project56.htm Figure one is intuitive for both voltage and current amps. Figure two and the voltages into 8 and 4 ohm loads has me stumped. The 18.8 with no load is straight forward enough, but I can't get to the 12.8 and 9.7 volt calculations. My guess was that for quick and dirty calculations gain is going to be set by r1 and (r2+r3) in both open and under load calculations. If so (and it appears not to be), I would have expected Load and r3 to give me the reported voltages under load as a simple voltage divider with 18.8 as the Vin. I suspect that I am grossly over simplifying. Can anyone point me in the right direction? |
#2 |
One thing to keep in mind is that he measured those values and didn't calculate them because he doesn't know the output impedance. You're doing those calculations assuming negligible output impedance compared to the load. That's a usual "rule of thumb" for voltage sources (most opamps). But in this case you have 3.75 ohms output impedance. So you can't ignore it because, it's basically like having 3.75 ohms in series with the output and before R1,R2,R3,Rl. Try adding a 3.75 ohm resistor between the output and R1 and then recalculating and see what you come up with.
-- Danny |
#3 | |
My goal is to sketch out a current amplifier with an 80ohm output impedence (following the F1's lead here if not all the way to class a and zero feedback). To do that I need to know how to calculate 1) The no load voltage (no problem) 2) Vout under load (don't understand... ) 3) Output impedence (well document in Project 56 based upon the availability of 1 and 2) Being able to calculate Vout under load where output impedence is *not* known, is the missing link. |
#4 | |
Aerodynamics are for people who can't build engines. Enzo Ferrari |
| Impedance analyzer on a chip | jackinnj | Solid State | 0 | 17th May 2008 01:27 PM |
| Simulating variable output impedance | abzug | Solid State | 3 | 30th December 2007 06:47 AM |
| BOSOZ--variable impedance volume attenuator | jh6you | Pass Labs | 22 | 15th March 2005 08:34 AM |
| How to measure the output impedance of the DAC chip | ergo | Solid State | 2 | 9th June 2004 07:07 AM |
| TI Introduces Industry's First Fully Integrated, Single-Chip 100-Watt Digital Audio A | mikejz84 | Chip Amps | 14 | 9th December 2003 07:37 AM |
