Bridged LM4780 Amp
Bridged LM4780 Amp
Old 19th March 2011, 06:35 PM   #11
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Bridged LM4780 Amp Bridged LM4780 Amp
If one of the internal chips don't work properly...the boards/construction is wasted.
(board will not be good after desoldering...) Strange that 2 boards act the same whithin 95%
Maybe I should go back to good old discrete amps.
Arne K
Don't believe everything you think...
Old 20th March 2011, 09:20 AM   #12
pacificblue is offline pacificblue  Germany
Originally Posted by Cobra2 View Post
I hear "scratching"
That sounds like the SPiKe system trying to protect the IC. You will have to doublecheck your amp for shorts, broken leads, correct component values and orientation, correct voltages everywhere, etc. Since the schematic is an exact copy of the datasheet application, it should work when correctly built.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 20th March 2011, 10:28 AM   #13
DIY !
Cobra2's Avatar
I also guessed it is some SPiKe issue...but why? Oscillation?
I have checked all component values. And all soldering-flux cleaned. Voltages...? I checked the mute-voltage, found it somewhat low to the mute-pins, tried a more direct route thru a 4,7k resistor, it is still low at ~-4,xV
Arne K
Old 20th March 2011, 10:43 AM   #14
R.I.P.
The mute pin requires current. Testing voltage does not answer the wrong question.
Using voltage drop and resistor value you can calculate the mute pin current, then check against the datasheet. Are there two mute pins?
regards Andrew T.
Old 20th March 2011, 11:40 AM   #15
DIY !
Cobra2's Avatar
Should only require 1mA /pin. So mute function is shot. Well, I can salvage some caps, and trow the rest into the dustbin.
Arne K
Old 22nd March 2011, 04:18 PM   #16
Redshift187 is offline Redshift187  Canada
I have those exact same boards, and they worked great when I last used them. 4V at the mute pin is probably fine, I have 3.6V at mine.
36V - 4V = 32V
32V / 4700R = 6.8mA
What impedance are your speakers?
+/-36V is REALLY high for bridged.
Tyler
Old 23rd March 2011, 10:05 AM   #17
R.I.P.
Hi Red,
4k7 seems very low for mute pin resistor using +-36Vdc supply.
National state the chip needs <0.2mA to turn fully on.
Any resistor value between 24k and 68k will satisfy this current requirement.
They also state that the amp starts to turn off when mute current ~<=0.15mA.
Your 4k7 will start to turn off when the supply voltage is down to 4V+ 4k7*0.15mA i.e. ~ 4.7Vdc.
The 9V lower limit has already shut down the power amp. The mute comes in far too late on loss of power.
regards Andrew T.
Old 24th March 2011, 04:36 AM   #18
I was just referring to the value he said he switched to.
Tyler
Old 2nd November 2012, 06:46 AM   #19
AudioEngineer is offline AudioEngineer
Cobra2 make sure the LM4780's are mounted on the heatsink properly and that you are using insulating pads between the chips and the heatsinks. Also make sure all of the power wires +V, -V-, GND are connected properly. Also I would recommend keeping all of the wires short as possible and keeping the high current wires (such as power wires and speaker wires) away from the small signal wires and components as much as you can. Return all grounds to a single point seperately i.e. use star grounding scheme.
Old 2nd November 2012, 04:17 PM   #20
DIY !
Cobra2's Avatar
That was abandoned a year ago, second try worked perfectly.
(Another PCB/layout)
Arne K
Bridged LM4780 AmpHide this!Advertise here!
Bridged lm4780 rs1026 Chip Amps 7 1st July 2016 02:08 AM
Parrallel/bridged LM4780 ?? pat allen Chip Amps 5 28th December 2006 04:00 AM
Lm4780 Bridged PCB Baracus Chip Amps 8 7th January 2006 12:45 AM
Bridged Lm4780. Up and running. sachi Chip Amps 0 15th December 2005 05:27 AM
Bridged Lm4780. Up and running! sachi Chip Amps 5 14th December 2005 04:37 PM
