| Chip Amps Amplifiers based on integrated circuits |
I am building a gainclone with 2 LM3875's per channel, and as I understand it I need to run 0.22 ohm resistors in series with the outputs of the amps.
I am also not sure about the watt rating of them, using the overture design spreadsheet i get 4.94 Amps. This going through a 0.22 watt resistor would be 5.5 watts (P=I^2 * R) I also understand that I will need 1% tolerance, does anyone know what type (i.e. wire wound, metal oxide), to get or where to get them? I see Digikey has an aluminum housed wire wound 0.2 ohm 10 watt, would this work? It looks tough to find a 0.22 ohm resistor with a high enough wattage rating. Any help would be appreciated |
#2 |
These are current sharing resistors. If you are going by the BPA 200 Application Note from National, they should be .1 ohm/1%/5 watt resistors.
The resistors spec'd on the datasheet are available here: http://www.mouser.com/index.cfm?hand..._pcodeid=71010 If you still want to go with the .22 ohm resistor, the closest you'll find is this: http://www.mouser.com/index.cfm?hand..._pcodeid=71010 Basically mouser carries the .2 or .25 ohm/5 watt Dale's. Good luck. |
#3 |
diyAudio Moderator Emeritus
I am using Vishay Dale LVR5 0.1 ohm resistors to go with the LM4780 in parallel configuration, and I expect that this will work good for the LM3875/3886 in parallel configuration also.
Here is a link to the part that I choose: http://www.mouser.com/index.cfm?hand...oductid=372142 -- Brian |
#4 |
I would say that matching is more important than the actual value in this case. If it was me, I'd go with the .25 so that I could be slightly less careful about matching the chips.
Edit: Then again, since the DS calls for .10, maybe you should go on the smaller side. Any reason you're choosing .22? -- Danny |
#5 | |
-- Brian |
#6 |
I just looked through the BPA 200 application.
I have 2 of the briangt kits ordered to parallel. Is there a reason that he specifies using 0.22 ohm resistors for parallel configuration and the BPA 200 specifies 0.1 ohm? |
#7 | |
http://www.jeffrowland.com/review16b.htm My current recommendation is 0.1ohm resistors, as they seem to work good with the LM4780 kits, and are recommended by National. I will change the manual to reflect this when I complete the next revision. -- Brian |
#8 |
Figures that while i am posting a reply there are 3 new answers.
Thanks for the help guys, I ended up getting the Vishay/Dale 5W 1% Low Value Power Resistors. I got a few extra to get a better chance at matching. How are you measuring the values? I have a fluke at home but I don't think it has a high enough resolution. |
#9 |
I have lots of Dale .22 ohms, something like 1% (reads 0.220 on meter).
They are surface mount though, but tabs could be pulled out. About 80mm long.. |
| 5 Watt Resistors on Aleph 4 and Holco Resistors | nicharis | Pass Labs | 16 | 8th February 2012 07:50 AM |
| FS: Resistors, LM3886, speaker terminal, variable resistors, switches and rectifiers | chris-man | Swap Meet | 1 | 28th May 2009 11:47 AM |
| paralleling resistors to reduce inductance but... | jarthel | Parts | 30 | 25th August 2006 12:15 PM |
| Paralleling transformers??? | dfdye | Chip Amps | 10 | 30th January 2006 05:26 PM |
| Page generated in 0.12392 seconds (66.42% PHP - 33.58% MySQL) with 10 queries |
