| Chip Amps Amplifiers based on integrated circuits |
Hello,
I just finished a lm3886 gainclone with an inverting t-net topology. There is no humming at the output and dc-offset is 7mV and 21mV. The Amp sounds pretty sweet but I get quite a bit of hissing HF noise. There might be little oscillation because the chips get a bit warm without source signal. Can any of you experts tell how to get rid of the problem? I am using PMA:s audio buffer as preamp. I have build several gainclones before and this is the first time I have problems with HF noise. PSU is snubbericerad a´la Carlos but the snubbers are located directly on the chip pins with 100nF bypass caps. |
#2 |
I have a similar problem with my lm3886 GC... although, my HF interference seems to be in the form of radio stations
This only happens with my input cable connected, however.I have posted about this problem before, one thing that was suggested was a LP filter on the input with a 470 ohm resistor and 1nf cap just before the decoupling capacitor (if you use one). I tried it and found it didn't really help but also didn't hurt, so its worth a try. For me, the next thing to try is better sheilding as I have an open air amp and no sheilding on the interconnects. my .02 -steve |
| Noise problem on DAC IC | DrVingTor | Digital Source | 0 | 3rd July 2006 09:17 AM |
| Noise Problem. | raveenvijendren | Solid State | 0 | 14th November 2005 06:03 AM |
| Noise Problem | Jackson Yaya | Solid State | 4 | 6th June 2005 06:08 PM |
| noise problem | danyel | Chip Amps | 3 | 23rd February 2005 10:59 AM |
| Port noise problem | ernieretief | Multi-Way | 9 | 4th August 2003 08:11 PM |
| Page generated in 0.08335 seconds (58.63% PHP - 41.37% MySQL) with 10 queries |
