| Chip Amps Amplifiers based on integrated circuits |
I rarely see many (if any) fuses on chip amps. I can find tons of schematics for large solid state amps that have a fuse before the transformer and one on each rail within the amp, but I never see more than a single fuse in a gainclone? Is the short circuit protection on the LMxxxx so good that fuses are not necessary?
#2 |
I think fuses and circuit protection is necessary,I do not hope the expensive loudspeaker is risky.
#3 |
I think a fuse before the transformer primary is assumed to be there, and thus not necessarily shown. You should most definitely not build anything mains powered without a fuse!
https://mrevil.asvachin.eu/ |
#4 |
Electrons are yellow and more is better!
The primary fuse is mainly for the protection of the transformer. Secondary fuses help better to protect things after the fuses. I have fuses in both locations, but that's me.
/Per-Anders (my first name) or P-A as my friends call me |
#5 |
Same here, one primary, two secondarys.
OT PA Du nämnde en trådleverantör i göteborg på hififorum, var det månne en trafolindare? om så, har du lust att berätta vad företaget heter? |
#6 |
Secondary fuses between the transformer's secondaries and the diode bridges, or after the bridges on each rail?
#7 | |
audio projects |
#8 |
best fuse is no fuse at all. Ceramic fuse 'mellows' the sound, but silver fuse can make the sound 'thin'
hehehe...Not using fuse is breaking the law from another point of view. I just use the fuse in the 3-pin plug for protection purpose. I didnt use secondary fuse for cost and simplicity reason. But if your chip is the last piece you have on earth, you better use it. |
#9 | |
#10 | |
audio projects |
| My Gainclones | cadbike | Chip Amps | 6 | 10th November 2005 03:47 PM |
| Gainclones in car amp | mmmax | Car Audio | 15 | 1st November 2005 06:16 PM |
| libraries for gainclones | barroccio | Chip Amps | 4 | 16th November 2004 10:25 AM |
| Big Gainclones | Ropie | Chip Amps | 4 | 12th July 2004 05:30 PM |
| Tell me about gainclones | Solid Snake | Solid State | 46 | 16th November 2003 10:59 PM |
| Page generated in 0.14304 seconds (59.46% PHP - 40.54% MySQL) with 10 queries |
