Cap or caps on ac inlet  ?
Old 2nd February 2005, 04:52 AM   #11
ROVSING is offline ROVSING  Denmark
ROVSING's Avatar
Thanks for the explanation RUNEBIVRIN i think i got it now, here is the picture anyway....
Frandsen
Old 2nd February 2005, 08:11 AM   #12
steenoe is offline steenoe  Denmark
steenoe's Avatar
A capacitor in series with the AC inlet
A question: Won't that limit the current draw capability, in case
this is implemented in a poweramp? In this case a GC.
The usual way is to place a X2 rated cap in parallel with the
AC lines. BUT, that doesn't really kill the DC residual on the AC line though! See pic for the usual way to do it. The trafo on the pic still suffers from a mechanical noise. The red component in the middle at the rear is a X2 rated Wima MKP, 0,1uF.
What we need is an easy to implement solution that takes care of the DC. Hopefully some of you guys can come with right one
for this problem. Perhaps, what is really needed is something like this?http://www.lcaudio.dk/index.php?page=12
Go down to "DC filter stop brummet" There you see a schematic.
Couldn't find the filter on the page in english, sorry.
Steen.
Old 2nd February 2005, 10:37 AM   #13
runebivrin is offline runebivrin  Sweden
runebivrin's Avatar
Send a message via MSN to runebivrin
Steen.
Well, that depends on the size (in F) of the capacitors. There won't be much voltage across it, so you can have rather large caps. As an example, 10 amps at 230 volts represents an impedance of 23 ohms. If you want the caps to have little impact, let's say you want 0.23 ohms impedance. That means the capacitors need to result in 14000F, or 28000 if you have two in series. That's a lot, but you'll only need 16V types (albeit large ripple current types.)
Scale according to power requirements, mains frequency and voltage.
Rune
Do wizards use spell checkers?
Old 3rd February 2005, 08:38 PM   #14
steenoe's Avatar
I am sorry, but do not exaktly understand!
Please clarify if you can! Are you talking about the X2 caps?
That would be an impossible value Normally rated about 0,1uF????? Or are you referring to the LC schematic?
I still feel that this would be a great thing for DIY'ers to solve??
Steen.
Old 3rd February 2005, 09:57 PM   #15
leadbelly is online now leadbelly  Canada
leadbelly's Avatar
That's unsafe practice. Everything on the mains side must be specifically mains rated and identified as such.
There are still unbridgeable divisions between cultures. How can two peoples ever come to understand each other when one of them is ignorant of Tot? Umberto Eco
Old 4th February 2005, 10:31 AM   #16
runebivrin's Avatar
Steen.
By placing capacitors in series with the transformer primary, you'll prevent any DC component from entering it. It's not about having a capacitor parallel with the transformer. See attached pic.
I can't comment on the legal issues, but from a technical standpoint that's ludicrous. I know for a fact that none of the light blubs in my christmas tree lights are rated at 230 volts.
See this for an example: URL=http://www.soundlabsgroup.com.au/lcaudio/lc_audio_mains_dcfilter.htm]LC Audio DC filter[/URL]
Rune
Old 4th February 2005, 03:45 PM   #17
leadbelly's Avatar
Apples and oranges. (1) Your Christmas tree lights have been IEC stamped somehow or you could not have bought them, so the assembly has been certified as a whole. Similarly that LC Labs product has likely gone through some process. (2) I never said that just putting a capacitor rated at 230V was what was required or even sufficient. The capacitor must be mains certified and labelled as such specifically. It must say something like 180VAC or 250VAC. Look in your electronics catalog for examples.
Old 4th February 2005, 03:56 PM   #18
ErikdeBest is offline ErikdeBest  Switzerland
mostly thinkerer
Maybe that cap was installed in parallel with the power switch. I think that it helps to prevent great inrush current, giving the switch a longer life...but a cassete recorder has no great power consumption. Well...don't know :S
(I took the drawing from a schematic from triodedick) www.triodedick.com
Old 4th February 2005, 09:19 PM   #19
runebivrin's Avatar
And I said "I can't comment on the legal issues", but nevertheless, there is no indication in LC Audio's product that the cap is anything but a bog standard electrolythic capacitor at 22000F/25V. It may be approved by some authority, but it doesn't say.
It's particularly interesting that the cap will be reverse polarized, albeit at a low voltage.
Are you suggesting that every component in a comupter power supply - which switches the rectified mains voltage - are somehow "mains rated"? Every single resistor?
The bulbs in my christmas light are not specifically certified for use in mains powered equipment, but I will grant you that the sockets most likely are, since they will have 230VAC across the contacts with a broken bulb.
Rune
Old 4th February 2005, 09:22 PM   #20
runebivrin's Avatar
That cap is useful, but not for inrush current, but for preventing voltage spikes on switch-off creating sparks that would shorten the life of the contact surfaces.
Different caps for different purposes!
Rune
Cap or caps on ac inlet  ?Hide this!Advertise here!
Wiring an IEC inlet mourip Parts 5 31st January 2013 06:02 PM
IEC Inlet with or without line filter for CD transport? pooya Digital Line Level 7 23rd August 2009 06:58 AM
IEC Inlet filter issue jkeny Solid State 23 2nd August 2008 04:31 PM
IEC Inlet Filter confusion jkeny Power Supplies 0 31st July 2008 09:17 PM
Replacing C7 inlet on the Panny 45 neilr11 Digital Source 0 25th December 2004 12:04 AM
