Using 2 chips to boost voltage handling
Old 2nd February 2005, 04:57 AM   #31
simon5 is offline simon5  Canada
You couldn't bias each OPamp with some DC offset of like 1,5 V ?
Like in a class AB?
DIYaudio for President !
Old 2nd February 2005, 05:47 AM   #32
Stocker is offline Stocker  United States
HDTVman, I am not saying you are wrong, as I suspect you are right. I recall however one webpage explaining opamp use fundamentals; there was a class-B output stage on the opamp the fellow was using... the output went from horrible crossover distortion to <0.1% with a wire (follower) for feedback.
If you could avoid clipping, or exploding chips, it could work eh?!
Jesus loves you.
Old 2nd February 2005, 12:55 PM   #33
HDTVman is offline HDTVman  United States
The problem is you are clipping as part of the design here. This is not at all like a discrete output stage. The design is being forced to be nonlinear at the 0 crossing because the + chip output can't go below some voltage greater than 0 volts, 1.5 v for example and the - chip can't go more + than -1.5 v. A 3 volt notch you can't avoid and the output can never be 0 volts.
With a class B amp stage at the 0 crossing no current flows and output voltage is 0 but as you start to turn on one of the transistors the voltage starts to increase. Yes you can help the nonlinearity of this type of output with feedback.
I would guess the page you refer to in the quote was using a single opamp in a more normal mode, and yes feedback could help a " Class B " output stage. The basic problem with the described circuit is that in reality it is not " Class B " but a push/pull "Class C " amp near "Class B".
BZ
What ever makes the tunes flow
Using 2 chips to boost voltage handlingHide this!Advertise here!
[enquiry] Treble Boost/High frequency Boost circuitry elnino86 Parts 2 18th December 2008 12:33 PM
Name some amp chips that work on a single rail voltage please speaker Chip Amps 13 22nd March 2008 08:23 PM
TL Power handling fortyquid Multi-Way 9 13th October 2003 12:18 AM
Power Handling Myren Multi-Way 1 30th October 2001 07:18 AM
