| Chip Amps Amplifiers based on integrated circuits |
hello
i had a search around, i couldn't seem to find anything for it, i cant seem to see any specific place for noobs, so as its chipamp based, here i am i constructed a lm3886 based amp with point-to-point wiring when the speaker is connected, it sits fully foreware (then backward if i swap the wires to the speaker around) from what i can gather, this would mean that there is a large dc signal being outputed is this a common problem for someone with little experience (only made a lm3875 b4, but that one worked) is there a simple thing i did wrong, or is this a complex problem that is going to take me forever to fix? cheers matt |
#2 |
Yes, it would appear to be a large DC offset. I hope that you have been using an old speaker for testing!
Without a circuit diagram of what you have done, we cannot really help you though!
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#3 |
i followed the data sheet, exept i didn't use a cap on the mute, would that be the cause?
i used a 1.8k on Rm im using 56v CT trans, with 4700uf instead of the 1000uf on the datasheet what causes a dc offset? |
#4 | |
#5 |
Yes, that voltage would be a problem, unless you are talking about 28-0-28.
If voltage is not the problem, one mistake that will cause the amp to output the full voltage of either rail, is to have an open circuit in the feedback loop. The amp is a differential amp, so it tries to zero the difference between the inverting and non-inverting inputs by changing the output. Feed back is required for this to work. No feedback, the amp pushes all the way to the rail. Sheldon |
#6 |
Try putting a 20k resistor from input to ground. Without a resistor there and with no source connected, the output will be the straight DC that's only a few volts less than what your rails are at.
You really don't need a capacitor for the mute pin. I think the capacitor just allows for a "pop and click free" startup and shutdown. Measure the voltage with a multimeter, also, before connecting to a speaker. Good luck!
#7 | |
#8 |
Or just short the input for the time being...
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#9 | |
it doesn't change when i put an input on it
its a 28-0-28 trans so i end up with around 40v rails to give me 80v Quote:
which pins are called the inverting and non-inverting inputs? is it the Vin+ and Vin- ? or are you talking about that connection between the output and the Vin- ? |
#10 | |
Vin+ is the non-inverting input. Vin- is the inverting input. If the input goes to Vin+, the amp is non-inverting (does not invert the signal). If the input goes to Vin- the amp will invert the signal at the output. Feedback from the output always goes to Vin-. You don't have to understand all the inner workings. For a simplified version of a non-inverting differential amp: If you apply a signal of +10mv to the non-inverting input, the amp will raise the output voltage until it sees a signal of +10mv at the inverting input. If your feedback ratio is 20:1 (the ratio of the feedback resistors) the output will need to raise to 200mv before Vin- is at +10mv. For an inverting amp: If you apply +10mv to the inverting input (the Vin+ is grounded), the amp will go to -200mv to get the Vin- back to 0 volts. If you've got an open connection from the output to the inverting input, the amp will go positive (negative for the inverted amp) until it reaches its maximum, which is just short of the rail voltage. try mateo88 and pinkmouses suggestions too. Easy things first. Sheldon |
| Looking Forward To Learning!!! | Meshakroots | Introductions | 1 | 22nd April 2009 02:33 PM |
| idea of a cost-no-subject, fully hornloaded speaker | angeloitacare | Multi-Way | 11 | 23rd April 2007 11:37 AM |
| How to make a speaker more forward sounding | andy2 | Multi-Way | 51 | 3rd September 2005 01:11 PM |
| Guidance for my new 7.1-System needed (Center, backward-Speaker) | Blitz | Multi-Way | 1 | 16th May 2005 06:32 PM |
| rotel rcd 855 spindle motor spins backward | P Howard | Digital Source | 2 | 18th April 2004 10:03 PM |
| Page generated in 0.16114 seconds (59.78% PHP - 40.22% MySQL) with 10 queries |
