Old 28th January 2005, 05:18 PM   #1
Question quick transformer for gianclone
hello, i'm building a gainclone for a school project and i need it to be finished over the weekend (due on monday...) so i need to get local parts...local meaning from radio shack (blech).
will this transfromer work O.K. for a simple gainclone?
this is the transformer
i know it probobly isn't the best thing in the world to use, but i need this thing done pretty quickly...
this also brings me to heatsinks...my school has a pretty nice shop area where i could get ahold of some aluminum bars about 3/4" by 2"...would those do okay for a heatsink? i'm using the lm 3875t, so its not isolated...
thanks!
Old 28th January 2005, 05:31 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
No, you need split secundaries and 2A is not enough to drive the amp.
Try again.
/Hugo
Old 28th January 2005, 05:37 PM   #3
Try again.
/Hugo
can you think of anything that i could cannibalize to take the transformer out of? i'm kinda desperate...
Old 28th January 2005, 05:55 PM   #4
Netlist's Avatar
I happened to find a suitable one in an old Sony receiver.
I managed to split the secundaries. Many old receivers in the 30-50W range should have something you can use.
/Hugo
Old 28th January 2005, 06:18 PM   #5
Yes. You do not need split secondaries or mega-amps for a simple approach. A bridge rectifier and a couple of the largest electrolytics (@ enough volts ) you can find and you're good to go......
Old 28th January 2005, 06:25 PM   #6
Default Aha!
2 questions...
This page makes it sound like i can use single secondaries...
if i don't get this done its fine, i can do some tard project instead, such as a blinking led or something stupid like that...
but i'd reaaaallly like to present a nice amp that i built myself
edited...i misread your post...
Old 28th January 2005, 07:38 PM   #7
azira is offline azira  United States
Yes, as long as it's a CT transformer which that one is. I used a 24VCT 5A transformer for my GC and it works fine. With respect to the current, since your rail voltage is about 12.5V and your load will be presumably 8-ohms, your peak current usage is around 1.5 A which this transformer can deliver. I suspect you'll be just fine although not delivering as much power as you could which is no problem. Now, considering that your load impedance will vary somewhat, you might current limit (ie clip) if you turn it fully on. But it'll work for this weekend.
However, if you're planning on building a stereo amp, I strongly suggest that you buy 2 of those trafos and power each side seperately since 1 trafo will not have enough current to deliver to both. Make sure to ground them together however for safety.
Danny
Old 28th January 2005, 07:45 PM   #8
Netlist's Avatar
I stand corrected after reading Brian's user guide
Some mods to the supply PCB are crusial however.
Go for it. You can always upgrade later.
/Hugo
Old 28th January 2005, 11:30 PM   #9
/Hugo
i'm not using his kit...i would if it were available but it wasnt' when i decided i wanted to use a kit...so i'm just wiring it part to part...
i need to fix some grounding issues tho...
so, the black wire goes to ground, the other 2 go to the bridge rectifier? is that correct?
Old 29th January 2005, 02:19 AM   #10
thomas997's Avatar
Yeah..
Just do a quick measuring test, you will get the full AC voltage across the outside leads. And using the ground lead you get half to each side.
btw you could use two of those radio shack transformers, primaries paralelled, secondaries in "phase".
Aluminum bar will be fine as long as the load isnt 4ohms, and the voltage isnt too high..
Quick transformer question Brit01 Tubes / Valves 5 23rd July 2009 07:26 PM
3 quick transformer questions gary h Tubes / Valves 16 22nd August 2008 12:06 AM
Another quick transformer question Hiwatt25 Chip Amps 6 8th February 2008 10:56 AM
Quick Transformer Question krzanik Tubes / Valves 2 17th May 2007 09:15 PM
quick transformer question VictorG Tubes / Valves 2 9th January 2004 09:00 PM
Page generated in 0.14222 seconds (64.64% PHP - 35.36% MySQL) with 11 queries
