Old 27th January 2005, 08:55 AM   #1
Default Suitable PSU for OPA627+BUF
Hi ppl,
Built this circuit as a headphone amp, currently running it using 4x9v batteries and would like to convert it to AC power. Also should i have input caps?
My source is a iPod and cans are HD600s.
Old 27th January 2005, 09:07 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
The need for input caps has nothing to do with batteries or AC power supply. It's your signal source and I'll guess it's still iPod?
/Per-Anders (my first name) or P-A as my friends call me
Old 27th January 2005, 10:52 AM   #3
tlmadsen's Avatar
Use a "in-wall" transformer, a brigde, a copule of E-lyt (2200-4700uF) and a set of LM317/Lm337 regulators and you are of.
Thomas
Old 27th January 2005, 11:19 AM   #4
Did it Himself
richie00boy's Avatar
You can't use a bridge with a normal/common AC wall-wart to get split rails of any real capacity. You must use a half-wave voltage doubler. See ESP project P05 for exactly what you need.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 27th January 2005, 12:03 PM   #5
brianuk is offline brianuk  United Kingdom
I agree with the Maplin line Rich
Oh yes and on topic! the P05, I use one and it'll do exactly what you need Shield. Funny though all the parts I got came from maplin, even some 47 Ohm resistors instead of 47K that I wanted
Old 27th January 2005, 04:07 PM   #6
jackinnj's Avatar
You can use a DC Wall Wart and split the rails -- one of the ways is to use a power opamp to create an artificial ground, I can't find the schematic I posted about a year ago, but here is something similar from ESP:
Old 27th January 2005, 06:48 PM   #7
Did it Himself
I knew somebody would post something like that It's more complicated though and still has a limited load that the artificial ground can cope with, but it should work OK for headphones.
Old 27th January 2005, 09:04 PM   #8
jackinnj's Avatar
you can always use a Burr-Brown opamp on steroids.
Old 27th January 2005, 09:29 PM   #9
Pan is offline Pan  Sweden
I used a BUF634 as ground driver with two 9V batteries and it was very good. I used it in class A mode to make sure it worked as a shunt regulator for all dynamic situations.
/Peter
Fs: Bb Opa627,637 vadimgal Swap Meet 6 14th January 2007 03:27 AM
The use of OPA627 HiFiNutNut Chip Amps 2 5th July 2005 06:17 AM
Fs: Opa627 skchan Swap Meet 6 5th August 2004 05:00 AM
Suitable regulated/filtered 4volt battery-valve power supply suitable for 6+ valves? Layberinthius Tubes / Valves 0 11th March 2004 08:49 PM
im looking for 3 opa627! kasra Swap Meet 16 20th December 2003 09:30 AM
Page generated in 0.14166 seconds (62.02% PHP - 37.98% MySQL) with 10 queries
