| Chip Amps Amplifiers based on integrated circuits |
Audio Junkie
Im new to the whole chip amp thing. can anyone suggest a circuit, or point me to where i can find a schematic for easy to build chip amp that will produce at least 30 watts @ 8 ohms clean???
Thanks ZC |
#2 | |
diyAudio Moderator Emeritus
Here is a link to the datasheet: http://www.national.com/ds.cgi/LM/LM3875.pdf -- Brian |
#3 |
Ditto what Brian said, but depending on the bass you might like to add a lower noise opamp at the front end with a pot in between to get some more gain and decent noise performance, but it depends on the output level of your bass. Some of my passive basses with Barts put out a really low level, and at the opposite extreme, my modified Alembic will drive a standard Pro poweramp to full output from the bass itself.
No need for PCBs, just wire it on a bit of perfboard. |
#4 |
You'll probably want to add a little tone control in there too. Just add it onto the opamp front end or before it.
-- danny |
#5 |
Audio Junkie
Thanks, I already have a pre-amp section with compression, eq, etc i just needed a simple, easy power amp.
I will take a look at the sheet. ZC |
| DIY Bass Practice Amp Out of Household Items | xsogol | Instruments and Amps | 0 | 3rd February 2009 09:44 PM |
| simple chip bass amp | jamie1107 | Chip Amps | 10 | 16th February 2008 08:28 PM |
| small bass boost addon for car chip amp? | 2fast | Car Audio | 3 | 10th June 2005 10:12 AM |
| Chip Amp for bass only | madman | Chip Amps | 18 | 24th March 2004 11:45 AM |
| Bass practice amp | FBLEAGH | Instruments and Amps | 4 | 19th November 2002 03:57 AM |
| Page generated in 0.11450 seconds (57.59% PHP - 42.41% MySQL) with 10 queries |
