Need help to connect my Noble pot
Old 25th January 2005, 11:28 PM   #1
kanaddict is offline kanaddict  Canada
Default Need help to connect my Noble pot
I want to install a nobble pot in my DIY amp. I'm new to electronic DIY and it look like my understanding of the drawing I have is not good.
The IN is surely for the + of each channel, but I need to know where to connect the -. I connected it to the right pin (center tap) and the Noble pot don't work as expected (start loud, fade and start going louder ) & if I connect the RCA plug I get no sound, If I pull them in a way that only the + is connected, then I get good sound. So, the problem is probably with the - connection. Maybe the arrow of the left pins represent the ground ? It start to make sence to me Then I'll have to solder the - there.
Thanks !
Daniel
Daniel
Old 26th January 2005, 12:08 AM   #2
chipco3434 is offline chipco3434  United States
The pins should be marked 1-4 and 5-8 for the two channels.
Pins 1 and 5 are not connected. 2 & 6 are signal in, 3 & 7 are signal out. Pins 4 & 8 go to ground.
Old 26th January 2005, 12:16 AM   #3
thanks a lot !
The pins are not marked, but your description correspond to what I was expecting as answer. So, I'll give it a try and will let you know if it work well !
Thanks again !
Daniel
Daniel
Old 26th January 2005, 04:49 PM   #4
just a little note to mention that my prblems are gone
The amp. is working well and I'll be able to listen to it seriously next weekend.
Thanks !
Daniel
Daniel
Need help to connect my Noble potHide this!Advertise here!
Noble 100K pot. mattjk Swap Meet 0 21st January 2008 02:50 AM
Noble resistors jkraxi Parts 3 5th January 2008 02:40 AM
alps or noble? lanchile07 Chip Amps 8 21st October 2007 03:28 AM
Which pot? Noble or Alps? Or another? deiksac Parts 1 12th May 2007 04:47 AM
noble stereo pot mantisory Everything Else 5 28th April 2005 05:39 PM
Copyright ©1999-2017 diyAudio
