High/Low-Pass filter calculations
Old 23rd January 2005, 06:52 PM   #1
Matttcattt is offline Matttcattt  England
Matttcattt's Avatar
Default High/Low-Pass filter calculations
Im planning to build some active filters. Searching the web came up with the perfect document - The SLOA093 ap note from TI on active filter design. One simple question. What units do the calculations use? Farads and Ohms right? I dont want to buy components 1,000,000 time too large. :P
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 23rd January 2005, 08:01 PM   #2
12 Cents is offline 12 Cents  Germany
12 Cents's Avatar
Default Re: High/Low-Pass filter calculations
I think it assumes just Farads and Ohms. Of course you can enter Millifarads, but be sure to treat the result as Milliohms
Old 23rd January 2005, 09:53 PM   #3
Matttcattt's Avatar
Thanks. I just wanted to get a second opinion.
Old 23rd January 2005, 10:24 PM   #4
rpapps is offline rpapps  Antarctica
Default Filter Calcs
Hi Matttcattt
The calculations are intended for basic units ie. ohms, farads and hertz. Just use the appropriate multiplier when entering your component values.
Eg. 100 pF = 100 x 10 to -12 power, 0.1 mF = 0.1 x 10 to -6 power, 1k ohm = 1 x 10 to +3 power, 10 KHz = 10 x 10 to +3 power. You get the idea?
Hope this helps.
Cheers
Rob
Old 24th January 2005, 10:55 PM   #5
Matttcattt's Avatar
Thanks.
I dont like standard form (1x10^-6F). I prefer long decimals (0.000001F).
Old 24th January 2005, 11:04 PM   #6
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
You could try the sim on National's website, Webbench, it uses real world values.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 25th January 2005, 10:17 PM   #7
Evan Shultz is offline Evan Shultz  United States
TI also has a rather powerful program called FilterPro that will automate much of this for active filters. You can choose topology and choose some components while allow the rest to be auto-selected. I'd check it out.
Old 26th January 2005, 04:28 AM   #8
thomas997 is offline thomas997  Canada
thomas997's Avatar
I agree, simple and easy to work with.
Here is the link: http://www-s.ti.com/sc/techzip/slvc003.zip
Old 26th January 2005, 06:38 PM   #9
Matttcattt's Avatar
I've already calculated the values and ordered the parts now, but I'll have a look anyway.
High/Low-Pass filter calculationsHide this!Advertise here!
Just to check - Is my high pass filter ok? revans Parts 21 11th March 2009 01:40 AM
20hz high pass filter Naudio Subwoofers 2 6th May 2008 03:51 PM
high gain 2nd order high pass active filter topology sreten Solid State 21 23rd March 2006 01:26 AM
Cheap high-pass filter liteshow Car Audio 2 5th July 2005 08:13 PM
Low/High Pass Filter fatpower17 Car Audio 1 28th June 2004 08:45 AM
Copyright ©1999-2017 diyAudio
