Old 22nd January 2005, 09:11 PM   #1
Default Alternative usage for LM3875
Hello! I was sitting here half bored until i came up with a idea, why not try to use them as a VSD (Variable Speed Drive) So i took a big transformer and hooked a secondary to the speaker outs on the 3875īs and the 230 primary to a fan and a motor. This is the result: http://hififorum.knaak.dk/Tekko/lm3875/ <-- 125Hz on the fas and over 600Hz on the motor using a function generator on the computer and the cassette deck as preamp. There is sound on both videos.
Old 22nd January 2005, 10:45 PM   #2
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Hi Tekko,
Could you not pump those AVI's into some encoder and make it wmv or something...this way it takes 10 minites to download!
Bas
I converted your Video7.avi to video7.wmv from 27mb to 2 mb...quality of the wmw is lower ofcourse
http://basenjes.de/video7.wmv
Old 23rd January 2005, 01:53 AM   #3
Send a message via AIM to DigitalJunkie
I had an idea about using a +12V audio amp chip (TDA7350,or many others.) as a driver for a small 12V-120/240Vac inverter.Add another chip with a nice 50/60hz sine wave,and suitable power trannie(wired "backwards" for step-up)and you're set.Doesn't seem too complicated.Add a couple pots to set the freq and level (voltage out),maybe replace them with fixed reistors after you get it all dialed in.
You wouldn't be able to get a whole lot of power,maybe 25W? (unless you could parallel the chips?) but it might be handy for recharging phones,pda's,laptops?,running a small CFL light,etc from 12V sources.
But one bonus is that it has a sinewave output,none of that "modified squarewave" stuff.
Old 23rd January 2005, 01:57 AM   #4
DigitalJunkie,
read this:
OP-AMP based car amp power supply
I had asked the same question before.
Old 23rd January 2005, 08:55 AM   #5
This is controlled via the computers soundcard and a function generator. I could encode them but i donīt have a encoder.
EQ usage skooter Car Audio 29 30th December 2007 09:28 PM
RCA R35, 39 & 57 Terminal Usage... mcelaj Tubes / Valves 1 3rd September 2006 11:14 PM
Usage of BUZ71A ?? SM7UYJ Solid State 8 28th December 2005 05:18 AM
Reducing the gain - LM3875 and alternative diodes :) quickshift Chip Amps 11 29th October 2005 10:00 AM
Car subwoofer usage in PA application chriscam Subwoofers 8 29th July 2003 09:58 AM
Page generated in 0.22502 seconds (32.07% PHP - 67.93% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
