Hey all again.
Ive been reading and reading brains manual and nuuk site on how to wire this thing and I want to make sure I do it right.
First of: On the boards what do PG, OUT, OG, SG, N, CHG all mean?
Next: I have two transformers and two rectifier boards, I got two of these http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=122-615
Heres the diagram:
2x115V
BLU *--- --- * BLK 0V
GRY --- --- RED 22V / 3.64A
VIO * --- --- * ORA 0V
BRN --- --- YEL 22V / 3.64A
For the primaries I tied The two 115s together and the two 0s.
Since Im doing mono blocks Im confused on how to wire the secondaries to the rectifier and from the rectifier to the amp.
If some would be so kind to explain how to do this Id really appreciate and I understand that asking a lot so thanks in advance.
Heres the diagram:
2x115V
Well heres a diagram of what I think is how Im suppose to wire it.
Im still wondering what OUT, OG, SG, N, CHG stand for?
In USA so using 115V in
Thanks.
Thanks.
jawbreak said:Well heres a diagram of what I think is how Im suppose to wire it.
Thanks.
The transformer wiring looks fine to me, but you have the colors (polarity) on your RCAs and output jacks reversed and you will also need to tie the AC GND into the Star Ground
OUT = output +
OG = output -
IN = input +
SG = input -
CHG = chassis ground
Let me know if you have any more questions.
Brian
jawbreak,
I'll give it a go. This is what I think.
OUT = signal OUT. so should go to red post
OG = signal Out Ground, so should go to black post
SG = Signal Ground, outer connection of RCA
N is really IN = signal IN, centre of RCA
CHG = CHassis Ground
So you probably need to swap SG and IN and also OUT and OG.
Edit: Too slow again.
grege said:jawbreak,
Almost
Brian
