Old 15th January 2005, 05:08 AM   #1
n00beR is offline n00beR  United Kingdom
Send a message via MSN to n00beR
Question OPA549 Gainclone Layout
Hi All,
I have been regitered here for a while now, but haven't made any contributions
I was wondering if you guys would be so kind as to have a look at my OPA549 Gainclone design.
My design is just "copies" of others I have seen, and jumbled around a bit to make it my own
I'm new to circuit design so all comments, tips and suggetions are welcome.
I will post the eagle file incase anyone wants a closer look.
But for now here is a screen shot:
Old 15th January 2005, 08:30 AM   #2
Default OPA549 Gainclone Layout
... and here is the eagle file:
::bleh::
Old 15th January 2005, 10:23 AM   #3
Alcaid is offline Alcaid  Norway
Alcaid's Avatar
There is no connection between signal ground and power ground.
Old 15th January 2005, 10:25 AM   #4
Alcaid's Avatar
also the gain is too high for the OPA549.
You have a voltage gain of (22/1+1=) 23.
Try something like 11. (1k and 10k resistors.)
Old 15th January 2005, 11:03 AM   #5
Alcaid's Avatar
The output trace from pin 1,2 is too thin. The OPA549 can deliever 8A continuous.
Old 15th January 2005, 11:11 AM   #6
I have applied your suggestions Alcaid, nd have attached the new image below.
Would this implementation suffice?
::bleh::
Old 15th January 2005, 11:18 AM   #7
Alcaid's Avatar
These chips need a low gain because of their low GBP, but remember that with a gain of 11 you need some more gain in another stage like an active preamplifier (or just an opamp circuit in the amp). I use a voltage gain of 3 in my DIY preamp, and 3 x 11 = 33 which would be sufficient.
Old 15th January 2005, 11:25 AM   #8
Alcaid's Avatar
Instead of using a jumper, you could connect SG-PG like this:
(The PCB will be a little bigger though)
Old 15th January 2005, 11:32 AM   #9
Alcaid's Avatar
+ a little Eagle tips:
Try to use a standard grid of something like 50 mils or 25 mils (grid set to inch) instead of 0.0001mm or what you were using. With that grid it is almost impossible to put the components/traces where you want them.
Old 15th January 2005, 11:44 AM   #10
LOL you beat me too it alcaid that was my next question, or could i join pins 3, 6 and 8 as they all connect to ground? or does this cause other problems?
::bleh::
Birth of another gainclone around OPA549 abid_rehan Chip Amps 22 10th May 2007 01:59 AM
p2p opa549 gainclone HIPCHECK Chip Amps 3 13th January 2005 08:43 PM
opa548/opa549 gainclone amp kozak Chip Amps 4 8th September 2004 02:12 AM
p2p gainclone layout Greg Erskine Chip Amps 27 25th August 2003 10:09 AM
Gainclone layout check.. Tensop Chip Amps 10 17th July 2003 07:11 PM
Page generated in 0.27942 seconds (32.16% PHP - 67.84% MySQL) with 11 queries
