| Chip Amps Amplifiers based on integrated circuits |
So the amp is on TDA 7294 and the problem is that the maximum output is only 30 Watts on 4 Ohms, +/- 27 Volts BUT in user manuals and instructions there are given two times more Watts. So If enyone knows where is the problem or how to solve that please leave the message.
Thanks |
#2 |
where did you see this 30W limitation?
Mine runs on 25V (DC) and outputs approx. 60W in 4 ohm
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease |
#3 |
Mine is 15 V (AC), 4 Ohms
P=U^2/2R So 15x15=225/(2x4)=28 W |
#4 |
P=UČ/R
#5 |
P= (V^2)/(2R) is only true when you are getting the peak value of the voltage. I dont believe thats the case, so use the formula Bricolo gave, what gives you almost 60 W power.
| tda 7293 and tda 7294 help | sagarverma | Chip Amps | 84 | 19th May 2012 03:40 AM |
| TDA 7294 Use it or go LM3886 | benje | Chip Amps | 6 | 8th January 2005 07:45 PM |
| TDA 7294 PCB - need help :) please | Szaflik | Chip Amps | 3 | 17th December 2004 08:51 AM |
| pcb for bridged tda 7294 | Dr Gonzo | Parts | 0 | 6th February 2004 09:41 PM |
| Page generated in 0.10407 seconds (51.48% PHP - 48.52% MySQL) with 10 queries |
