Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Thread Tools
Old 13th January 2005, 03:18 AM   #11
jackinnj's Avatar
the LM4780 is basically a pair of LM3886's -- the design by National Semi on the LM4780 PDF works very nicely indeed if you have to bridge -- I see no reason that a pair of LM3886's shouldnt do as nicely providing that they are properly heatsinked.
Old 13th January 2005, 05:01 AM   #12
yeah, i'm not conviced the distortion would cancel as opposed to summing. if the distortion was in phase on both amplifers then yes, but as it stands, i'm not conviced this will happen.
if only it could be used for good, not evil...
Old 13th January 2005, 08:51 AM   #13
pinkmouse's Avatar
OK, this sounds like an ideal job for someone with one of those spice simulator things. Sim the two designs, (they can be any old op amps in the sim, it's the principal of the thing that matters ), and see how the two distortion figures come out. Or, of course, someone with the two amp configurations could just measure them I suppose!
Al
There is science, logic, reason; there is thought verified by experience. And then there is California. Edward Abbey
Old 13th January 2005, 10:34 AM   #14
arcom is offline arcom
I think that this is the common bridging technique for most chip amps. I have used it in my TDA7294 amp and it works great!
Old 13th January 2005, 02:04 PM   #15
jackinnj's Avatar
in theory, it works perfectly -- i put it on Multisim8 and there is no distortion to speak of:
in the real world I have found distortion of 0.01 to 0.07% with the capacitor coupled, bridged LM4780
Old 13th January 2005, 02:34 PM   #16
pinkmouse's Avatar
Originally posted by jackinnj
iin the real world I have found distortion of 0.01 to 0.07% with the capacitor coupled, bridged LM4780
I wonder if one of the differences between sim and real life comes down to tolerance in other components between the chips. Could this be reduced by more exact gain matching I wonder?
Al
Old 13th January 2005, 02:57 PM   #17
jackinnj's Avatar
I guess I should put up the picture -- with the resistors matched to 0.1% there is a slight difference in gain between the A and B channels -- Gain on A is 19.67dB, and on B it is 19.77dB. I am averaging 64 samples of a 1kHz signal.
Old 13th January 2005, 07:23 PM   #18
ingrast is offline ingrast
Gain matching is not an issue in a bridge configuration except for efficiency (max available output at exact matching). If one side has 100% gain and the other 50%, then the output voltage will be 150% compared with the single ended case.
Below 0.01% THD, other issues like PSU and layout are much more relevant.
Rodolfo
Old 13th January 2005, 07:45 PM   #19
pinkmouse's Avatar
Thanks for clearing that up Rudolfo, little tips like that are often the things you miss when you are teaching yourself.
Al
Old 13th January 2005, 09:57 PM   #20
TwoSpoons's Avatar
The problem with the sim is that the model generally does not include the non-linear elements that create the distortion. Op-amp macro models are pretty simplistic.
Thread Tools
A LM3886 "Stasis" Power Buffer mauropenasa Chip Amps 35 10th March 2010 06:57 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
ISO "Simplest" possible amplifier dano12 Solid State 32 27th February 2009 10:07 PM
Need your opinion, how small gain can I use with LM3886 (how close to "flat amp")? danielwritesbac Chip Amps 20 30th November 2008 12:27 AM
Page generated in 0.09183407 seconds (78.39% PHP - 21.61% MySQL) with 11 queries
Copyright ©1999-2010 diyAudio
