| Chip Amps Amplifiers based on integrated circuits |
I'm building a LM3875 mono blocks and am having some questions on how to properly ground it.
I'm thinking of having the two toriods in one box and havng two umbilicord cables connecting to the two blocks. Now is there one star ground for the whole thing or more for each case? one for each case and in turn all connected together? I want to make sure its case is safe from conducting a voltage. Thanks. |
#3 |
Treat the amps as two monblocks even though the transformers are in the same case.
The transformer case must be connected to the mains earth for safety (if using two mains leads, just connect one earth) and your umbilicals to each amp case must carry mains earth as well. In the amps, connect the case to the mains earth and to the power ground star via a resistor and cap as shown on my site.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#4 |
Thanks for the replies.
Nuuk your site has been a great resource since I've started this project, thanks for taking the time to doing it. Heres a pic of what I think you mean: The ground symbol represents connection to the case. ![]() Is this correct? Also does anything else get connected to the ground in the power supply case? |
#5 |
Yes, that's how I would do it!
#6 |
Hello,
I would like to use the umbilical connection for my 3886 GC. I already have a pair of 4-pole connectors to make two umbilicals. I see on the Platenspeler.Com site this has been done (with 4-pole connector) but I cannot see/understand which conductors can be coupled or how for the (5°) star ground. I excuse my ignorance. Pole/Line (for each channel) 1°/V+ 2°/V- 3°/PGND+ 4°/PGND- and for the GND??? Thanks to all! mv
| Meridian 605 Mono Blocks | ANTHONY2181 | Solid State | 30 | 2nd February 2011 11:29 PM |
| PP KT88 Mono blocks? | TubeMack | Tubes / Valves | 38 | 11th June 2009 05:41 PM |
| heathkit aa-81 mono blocks | joshuahhhhhhh | Tubes / Valves | 14 | 31st December 2007 07:23 PM |
| Heath Kit W5M mono blocks | Jed | Swap Meet | 2 | 12th January 2007 03:37 AM |
| TQWT with IGC Mono blocks | ronc | Chip Amps | 4 | 22nd December 2003 01:05 AM |
| Page generated in 0.10871 seconds (65.52% PHP - 34.48% MySQL) with 10 queries |
