diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Chip Amps (http://www.diyaudio.com/forums/chip-amps/)
-   -   speaker protection and output short (http://www.diyaudio.com/forums/chip-amps/49270-speaker-protection-output-short.html)
patriz 10th January 2005 11:26 AM
I pick up in some post to use the speaker protection with the realy not in series with the signal but shunt to ground so if I have some dc the realy swicth the output to to ground but this mean output short . Lm3875 datasheet speak of in chip short output protection , this mean I can use this idea with no problem?
Gio
Nuuk 10th January 2005 12:40 PM
When shunting the input of the LM3875 to ground, you need normally closed relays whereas the relays used for the speaker protection modules are the normally open type.
But yes, it is OK to shunt the input of the LM3875 to ground while the amp powers up.
patriz 10th January 2005 02:06 PM
actually my idea was to shunt the 3875 output to ground in order to avoid dc in the speaker. The problem could be, in a protection project like the Velleman kt4700 with the soft start , all the time before the relays activation the output is shorted to ground
Nuuk 10th January 2005 03:55 PM
AFAIK, all the Velleman 4700 does is disconnect the speakers from the amp for a short while before the amp is fully powered up.
Resources saved on this page: MySQL 18.75%
