Old 9th January 2005, 06:41 PM   #11
endia is offline endia  Turkey
Originally posted by Sherman
I wire AC1 to the AC1H connection in the PS. Then wire the CT to both AC1N and AC2H. Wire the AC2 tap from the transformer to AC2N.
Sherman, thanks to schematic, i'll do it that way but i have a question;
AC1 and AC2 (from the transformer) are our hot wires, aren't they? why we don't wire AC1 to AC1H, AC2 to AC2H and then CT to both AC1N and AC2N?
Old 9th January 2005, 09:09 PM   #12
Did it Himself
richie00boy's Avatar
If you use two bridges and have twin secondaries, you load the transformer better so can get a little more current out of it for the same temperature.
Also, it's better from a grounding perspective as when the top half circulates current it does not travel in the same ground loop as the bottom half, and the star ground really is only at the centre point of the smoothing caps. With a single bridge or centre tapped transformer, the star point is shared between the caps and the tap, so the length of this connection is important/influential.
Old 26th January 2005, 07:41 PM   #13
I modified my center-tapped transformer in order to have twin secondaries, is it better to wire one secondary out of phase anyway???
One transformer with 4 secondaries or two transformers with dual secondaries Baka Chip Amps 5 28th November 2008 06:39 AM
need help on transformer secondaries connection atenolol50 Tubes / Valves 6 26th September 2008 08:52 AM
how to Using single secondaries transformer for snubber psu triast Chip Amps 18 10th September 2006 10:40 AM
Paralleling transformer secondaries. commstech Parts 4 28th November 2004 06:53 AM
Dangers in connecting transformer secondaries. PetarLD Solid State 8 24th June 2004 02:37 AM
Copyright ©1999-2013 diyAudio
