| Chip Amps Amplifiers based on integrated circuits |
Hi, I have some MUR860 diodes for a 3886 gc, do I need heatsinks for them or will current be low enough that they can live without them?
#2 |
I have no technical information other than my experience. They don't even get warm with a 3875 driven hard. So, no.
#3 |
A pair of small heatsinks surely won't hurt. LM3886 has twice the current capability of LM3875
Nothing is as simple as it seems |
#4 | |
If they do, buy some bigger diodes. |
#5 |
If the amp is drawing twice the current, the diodes will have twice the dissipation and be twice as hot! In reality, there likely won't be a large difference unless you are pushing the amp and using all that extra current capability, but the point is quite valid.
#6 |
They're in a TO220 case, typical thermal resistance (bare tab) 60C/W. Averaging 2A (which is a lot when you consider they're only conducting half the time) they'd waste 2W and get damned hot but survive.
So do the maths for your amp. |
#7 |
thanks guys
| Controlling regulator heat via sinking/shielding | hollowman | Power Supplies | 17 | 29th October 2008 04:51 PM |
| hybrid power supply: diode bridge into diode tube | engels | Tubes / Valves | 8 | 24th September 2007 09:18 AM |
| Try counter sinking this one. | Eton | Multi-Way | 8 | 22nd July 2007 11:24 PM |
| Heat sinking power per frequency ??? | Jennice | Everything Else | 8 | 16th July 2004 10:58 AM |
| XSOZ/Complementary Zen heat sinking question | needtubes | Pass Labs | 5 | 5th April 2004 09:28 PM |
| Page generated in 0.09115 seconds (72.12% PHP - 27.88% MySQL) with 10 queries |
