| Chip Amps Amplifiers based on integrated circuits |
I need schematics for a good ic preamp. I'll take all the help I can get
#2 |
Hi!
Do you need just a preamp, or should it include tone controls as well? You can try with TDA1524A from Philips or LM1036 from National. |
#3 |
Have a look at project 88 or project 97 from sound.westhost.com
/U. |
#4 |
Yes just a preamp
I made project 88 and 97 I'm looking for something different |
#6 |
Thank You
That 1. I need at least four more |
#8 |
Looking for more in on preamps
look at this http://www.mhennessy.f9.co.uk/preamp/index.htm keep you occupied for at least an hour or two?
Indecision makes the world gone round. Maybe |
#9 |
Hi.
As Alcaid suggested, the PMA -Pavel Macura- buffer alternative is a very good one. Check out if you need some gain, ´cause the system in the picture doesn´t have any. But it´s easy to re-arrange and convert it in a preamp. Check out Burr Brown´s appl.note ¨combining an amplifier with the buf634¨ in the link below. I´m using something very similar, with a gain of 2.5, based on opa602ap. The BUF634 runs in high bandwidth mode -with little heatsinks attached, because in that config. the chip gets real hot-. I recommend you with great confidence the OPA602: it´s not too picky a chip to use in this application, very stable and with excelent dynamics, but paradoxically with a superbly smooth sound. You´ll never get tired of it. I have checked OPA134, 604 and 627 too. The latter is very, very good and revealing. But I happen to like more the 602. If you use some sockets, you can change opas and make decisions more easily. Enjoy! PS: the link, http://focus.ti.com/lit/an/sboa065/sboa065.pdf[/URL] |
#10 |
Jaudio, why don´t you try something very simple? -I mean a single opamp in some basic configuration, be it inverting or non inverting (it's up to your liking).
Previous to my experience with the opa/buf combo, I tried a simple topology for opa627: non inverting, gain 3, 2uF input cap, 100 k input impedance, 50ohms output resistor... Add a good regulated PSU, +/-15v , with some fancy 2200 uF reservoir caps, and with good decoupling close to the chip -some paralleled 100n and 100uF from each opamp psu pin to ground-, and maybe you´ll get something interesting. I have had very good results with that scheme. If you only need to feed a normal input impedance power amp with not very long interconnecting cables, you can skip the use of buffer chips. Cheers |
| Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps | MartyM | Tubes / Valves | 3 | 16th October 2008 04:52 AM |
| simple chip phono preamp | dewdude | Chip Amps | 4 | 23rd May 2008 04:37 PM |
| Chip phono preamp | Paul Ebert | Chip Amps | 12 | 23rd November 2007 08:29 PM |
| chip preamp for my chipamp? | Russ White | Chip Amps | 3 | 9th March 2005 03:51 PM |
| Preamp Chip LM1895 | r_s_dhar | Solid State | 6 | 24th June 2002 09:03 AM |
| Page generated in 0.09150 seconds (81.24% PHP - 18.76% MySQL) with 10 queries |
