Old 6th January 2005, 07:11 AM   #1
jives11 is offline jives11  Europe
jives11's Avatar
Default simple PC mini-amp project ?
I have a PC with a sound card and some cheap active speakers. I also have some better passive speakers (RadioShack Genexa s with Lineaum tweeters). The speakers provide some music and some effects for games. Not too critical. It would be good if I could use the passive speakers with the PC , So ....
I could get a commercial power amp, but really want something smaller which will fit on my desk without taking up too much space. It would also be good if the amp could be run from a 12v dc supply as I have a PCI card which provides external supplies off of the PC PSU.
I'm kind of surprised that a commercial 12v mini amp doesn't exist as it could be used with mp3/cd/iPod type applications and anywhere there existed a 12v supply (i.e a boat, caravan etc)
I was thinking about a couple of mono chipamps with a 10Klog put to provide some volume control.
anyone had any experience in this area or can recomend a design ?
So ......
anyone built a chipamp for this kind of application ?
Old 6th January 2005, 07:44 AM   #2
Need to know power of your PC PSU and 12V DC current on PCI card.
Old 6th January 2005, 07:52 AM   #3
purplepeople's Avatar
Default Re: simple PC mini-amp project ?
Actually, they're called car stereos. Your chip amp idea is good. Both the LM4750 and the TPA1517 can use 12v single supply and provide around 5W with 1% THD+N. The TI chip seems to have a better SNR and less distortion and noise at any given output.
:)ensen.
Those who claim to be making history are often the same ones repeating it.
Old 6th January 2005, 07:54 AM   #4
Bill Fitzpatrick's Avatar
There are tens of millions of mini-amps that run from 12vdc. Simply visit your car stereo dealer.
Rats, someone beat me to it.
Old 6th January 2005, 08:16 AM   #5
If you want to build something yourself have a look at the TDA2003 10W amplifier.
http://www.electronic-kits-and-proje...ts/tda2003.pdf
Old 6th January 2005, 08:21 AM   #6
UrSv is offline UrSv  Sweden
UrSv's Avatar
Depending on what you mean with mini-amp then several thousands probably exist as pointed out by others. The one below has created a religious following and is used by many to power their main systems.
It's small, runs off 12 V and apparently sounds great:
http://www.sjgreatdeals.com/sit5066.html
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 6th January 2005, 08:52 AM   #7
DT is offline DT  Lithuania
DT's Avatar
Send a message via AIM to DT Send a message via MSN to DT Send a message via Yahoo to DT
Some years ago i have build for my computer sound system a 12V amplifier on TDA2005 with regulator, standart schematic. And till now this tiny amp sounds for me very nice
Schematic can be found on datasheet or on my site:
TDA2005 amp
and some photos ...
Dainius
Old 6th January 2005, 07:50 PM   #8
mcs is offline mcs  Denmark
I made a small amp using the TDA1510 some years ago - but I think that chip is obsolete now...
Best regards,
Mikkel C. Simonsen
My personal electronics website
Remote control kits website
Old 6th January 2005, 07:56 PM   #9
Bill: I'm not trying to prevent you having any fun... honest!
UrSv: That's the digital amp that everyone's been talking about modding in another thread.
DT: That is one big faceplate!
:)ensen
Old 6th January 2005, 08:03 PM   #10
jives11's Avatar
Default Thanks to one and all
Many thanks for the responses.
Car stereos - of course. yes - an inspired suggestion
The PCI power card is really a module which slots in a PCI slot and exposes 3,5 or 12Volt supplies as tapped off spare ATX PSU taps. I thinkmost PC's can deliver high current , possibly as high as 5 amps. However these are switched mode supplies so probably quite noisey.
however the Sonic Impact 5066 digital amp looks to be "exactly" what I had in mind. Now just got to figure out how to get one to Europe. Odd that they are US only as they have no regional PSU changes to make. Many thanks
DIY mini speaker project Driver_King Multi-Way 27 1st December 2008 06:30 PM
Dual hi-vi mini project BionicSniper Multi-Way 23 7th August 2008 04:06 PM
Mini cum laude 3-way project thread max_andrews Multi-Way 22 4th February 2008 09:24 PM
mini Zen5 & JBOZ project yggdrasil Pass Labs 7 19th January 2008 06:46 PM
Mini-Monitor Project Going On gary f Multi-Way 29 20th March 2004 03:45 AM
Page generated in 0.09023 seconds (85.57% PHP - 14.43% MySQL) with 10 queries
