| Chip Amps Amplifiers based on integrated circuits |
When you mount the LM4780 on the heat sink it's a good idea to use a small piece of aluminum stock to secure the chip onto the heatsink -- the picture below is a proto using 1/8" stock -- please excuse the fact that the screws don't match!
![]() The LM4780 is two LM3886's but with a smaller surface area for contact with the heat sink. Thus the thermal connection is even more important than for the LM3875 and LM3886. I milled a bit of the stock away so that the chip is pulled tightly to the sink-- you could use a file to do the same thing. I found that the amplifier would cycle in out with the SPIKE protection, until I put a girdle on the darned thing. btw, the heat sink is around 1.6 C/W. |
#2 |
Looks like a good idea. Perhaps it would be even better if the aluminium was bevelled very slightly to ensure most pressure is applied to the centre of the package (I assume that's where the most heat is generated - I've never opened one up to look)?
https://mrevil.asvachin.eu/ |
#3 |
you can't see it from this angle, but I milled off enough so that it snugs up tight.
#4 |
I do the same with the LM3886 to better spread screw pressure on the tab.
For rigidity, I prefer a "L" profile (abt. 7x7 mm, 1.5 mm width). For the LM4780 it should be a good idea to extend the piece length in order to complete the screw holes. Rodolfo |
| LM3886 Heatsinking | englandinacan | Chip Amps | 6 | 14th April 2009 06:20 PM |
| heatsinking | Ted205 | Chip Amps | 24 | 30th August 2008 08:50 AM |
| lm4780 heatsinking... | morpheus82 | Chip Amps | 14 | 21st February 2007 01:10 PM |
| Class A heatsinking, or heatsinking in general! | NUTTTR | Solid State | 27 | 22nd January 2005 01:48 PM |
| Heatsinking has now become less dense! | cunningham | Solid State | 5 | 9th November 2004 07:09 AM |
| Page generated in 0.06890 seconds (74.64% PHP - 25.36% MySQL) with 10 queries |
