| Chip Amps Amplifiers based on integrated circuits |
I’ve been checking out the forum for a while now and I think I am going to build a gainclone. I will probably get the LM3875 kit when they are available again from chipamp.com.
I have a few questions though. I will be building a 2 channel amp with room for a third channel later. The speakers that this will be powering are 4 ohm MTM’s. I have been looking around and understand that with 4 ohm speakers a lower voltage (~25V rails) power supply should be used. I think I have the terminology correct, the rail voltage would be 1.41 * the transformer voltage I have also read that you can run 2 amps in parallel (with a .22 ohm resister) to drive lower ohm speakers. Do I put a resistor on each output and then combine? In the manual for the kits it talks a little about running a parallel configuration and says that the amp will see double the load. says this will give higher power but not double. Does anyone know what kind of power I could expect? If I do this, can I run higher voltage (31V rails) to the amps? I plan on getting a transformer with around 400-500 VA or should I do this or run with 1 transformer for each channel? |
#2 |
I think lm3886 would be better 4ohm speaker,if you use a single chip
Yes lower voltage would make it easier on the chip Yes the voltage is around 1.414*transformer secondary Yes one resistor goto each chip output then combined Goto I believe www.the12volt.com there are programs for getting output power |
#3 |
are their kits with the LM3886? I don't have any clue about designing or building a PCB, and I don't want to do a PTP
A lower voltage would be easier on the chip, but if I use adequate heat sinking could I run with higher voltage and be safe? I am also curious about regulated power supplies. What advantages does this give? I looked around at 12volt.com but it looked mainly geared for car audio, I didn't see anything about amplifier power. - will have to look harder |
#4 |
Yes It should not be much of a search to find a lm3886 kit,so do a net search
Yes with a big enough heatsink you can use higher voltage but nothing over 40volts(lm3886) between 30 and 35volts should do goto www.the12volt.com then look for "ohm law" you will see a chart and calculators |
#5 |
Ejn327 Get the application note for whatever chip, the kits uses. You find information about how much power,you will get for a certain voltage supply
#6 |
National Semi has the following tool that you can use -- it also has the equations for parallel and bridged amplifiers:
http://www.national.com/appinfo/audi...gn_Guide15.xls |
#7 |
thanks for the links guys. I ran some numbers using the spreadsheet from national for 18, 22 and 25V transformers. It looks like if I go with the parallel 3875 and use 18V I would get 93W. Anything above this (i.e. 22V or 25V) is current limited and the output stays at 95W.
Seems like a no brainer to go with the 18V supply. |
| FS: 4 Channel Parallel LM4780 gainclone | Matt_Tillard | Swap Meet | 8 | 10th January 2007 08:08 PM |
| gainclone chips in Parallel | steven344 | Chip Amps | 2 | 21st November 2005 04:52 PM |
| *pics* parallel gainclone finished | rwaudio | Chip Amps | 10 | 3rd November 2004 10:59 PM |
| Another parallel gainclone (Pics) | Jye | Chip Amps | 2 | 2nd November 2004 11:10 PM |
| Gainclone in parallel mode | palesha | Chip Amps | 6 | 28th May 2004 11:29 AM |
| Page generated in 0.08938 seconds (77.70% PHP - 22.30% MySQL) with 10 queries |
