Old 15th March 2012, 08:05 PM   #611
PauloPT is offline PauloPT  Portugal
Send a message via MSN to PauloPT
Default Old thread, new question
I if want to use this design with a few LM338 in parallel, do the caps and resistors of the snubbers stay with same values or divide the values by the number of paralleled devices?
Thanks.
Kind Regards,
Paulo.
Old 17th March 2012, 11:37 PM   #612
gootee is offline gootee  United States
The snubber is the resistor. The cap is just there to determine which frequencies the snubber resistor gets to see, so it doesn't dissipate too much power. So I think that the cap value would stay the same, since the frequencies involved would be the same.
Not sure about the resistor but don't see any reason to change its value.
Old 18th March 2012, 09:19 AM   #613
Send a message via Yahoo to mikelm
You could say that you are snubberizing the power supply and the what you connect it to doesn't change the snubber circuit
or . . .
You could add a snubber for each chip
It will depend on your layout.
Old 18th March 2012, 04:35 PM   #614
So if I parallel 3 LM338 I don't get 3 times less the output impedance and I don't have to take this in to account when calculating the resistor/cap value?
The values of the cap/resistor are different in the unregulated and regulated supplies. Shouldn't it be the same values?
The schematics I'm using is the one on the pic.
thanks.
Kind Regards,
Paulo.
Old 18th March 2012, 07:35 PM   #615
Gopher is offline Gopher  United Kingdom
PauloPT
You can't just parallel 3 regs. You'd have to use ~0R1 balancing resistors on the output of each reg to prevent one reg hogging all the current.
Old 18th March 2012, 09:05 PM   #616
Yes, I know that.
What I don't know is how to change the parts in the snnuber to acomodate the new impedance of the 3 paralleled circuits.
Kind Regards,
Paulo.
Old 19th March 2012, 01:22 AM   #617
just leave it the same - that's what I would do
mike
Old 19th March 2012, 04:57 AM   #618
I don't know that it's acting as a typical snubber, anyway. It looks more like a way to guarantee at least 0.47 Ohms of ESR for the 47 uF output cap, maybe since the cap's own ESR would drop quickly as frequency increased.
You could either use one snubber per regulator, or one snubber after their parallel outputs have been merged together, or, one per regulator and also one after the outputs have been merged.
If you want to know how snubber component values are calculated, there are several good papers on the web. Just google "snubber design".
If you have a scope and can put some fast-rising square waves into the amp that's being driven by the PSU, you might be able to use the practical method, at:
paralleling film caps with electrolytic caps
Carlos' snubberized Gainclone Power supply, Part II peranders Chip Amps 77 17th September 2009 09:14 PM
Copyright ©1999-2013 diyAudio
