Old 31st December 2004, 09:16 AM   #1
TomekZ is offline TomekZ  United States
Default gainclone with tube preamp
Presently, I've 3 gainclones made by different people. All work fine with a passive preamp, but only one gainclone is buzz free when used with a tube preamp. I've tried two tube preamps: Audible Illusions3 & Mapletree Ultra4. The maker of the gainclone that does not buzz is not sure exactly why his works with tube preamps, but speculates that he had a bit of buzz when he had a 47k input load rating, but now uses a 100k input. Any ideas about this? or similar experiences with a tube preamp?
Old 31st December 2004, 10:16 AM   #2
Franz G is offline Franz G  Switzerland
Franz G's Avatar
I think, you can give you the answer yourself:
Just analyze the grounding scheme of this three amps and compare.
I am quite sure, the solution is in the grounding of the not humming amp.
Franz
/EDIT: You should not ask the producer of the perfect amp, what could be wrong with the other ones
Old 31st December 2004, 10:12 PM   #3
Joe Rasmussen's Avatar
Send a message via MSN to Joe Rasmussen
Maybe this page/link below might help, I've updated it recently.
members.ozemail.com.au/~lisaras/ps.htm
If you follow the grounding suggestions here exactly, I can almost guarantee that earth induced buzzes will be solved. I say almost only just to cover myself as I cannot actually be there.
Joe R.
"I wouldn't be so paranoid if everybody didn't hate me." - Frank Burns
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps MartyM Tubes / Valves 3 16th October 2008 05:52 AM
Tube Preamp for Inverted Gainclone 5150ed Chip Amps 0 14th July 2006 04:23 PM
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 15 24th November 2005 02:19 AM
tube preamp to mate with Gainclone JAZZ2250 Chip Amps 74 2nd May 2003 10:52 AM
Page generated in 0.08104 seconds (72.90% PHP - 27.10% MySQL) with 10 queries
