CMOY!  Help a Newb, Feel Good About Yourself
Old 23rd March 2005, 04:47 PM   #21
Wyloch is offline Wyloch  United States
Oh, man. The symptoms you're describing sound exactly like what I was getting when I was working on my first one. The answer is probably not your problem, givin that you're far from being an amateur, but it came down to the wire I was using to go from my CD player to the amp input jack. It was a standard 1/8 mini to mini, except it only had one ring on the tip: it was mono. I switched it out for a cable with two rings on the tip and the damn thing sprang to life. Again, probably not your problem, but what you're describing matches so closely I though it was worth mentioning.
Provided that that is not the problem, can you post a pic of the PCB you're using? I always just use protoboard...
ALSO, moreoever, where exactly are you? Have you wired up the input/output jacks yet? Do you have a pot or LED in there? Is it in the chassis yet? Or are you still in testing with alligator clips?
Old 23rd March 2005, 10:26 PM   #22
Bose(o) is offline Bose(o)  Canada
Thank you for replying Wyloch!
I'll swap my cable none the less, it's from Ratshack and I figure it's been screwing up the audio for my tuner card.
I'm at about the 7th rebuild of the circuit, I have everything on my breadboard (no pcb or proto yet), so I can easily swap and make adjustments, measurements, etc.
Not sure if this will help, but throwing in a sine wave (full blast, 0dB. 100Hz.) input voltage = 0.678V (pin 3), pin 2 (inverting input) ~ 0.330V and pin 1 (output) ~0.0166V. This is definitely not gaining at all.
I'll be back!
ERTW 4 life!
"the day has 24hours. If that is not enough take the night."-Roemhild
CMOY!  Help a Newb, Feel Good About YourselfHide this!Advertise here!
Newb Questions, looking for good learning material jmartinson Chip Amps 5 11th May 2003 12:57 AM
Help me, I feel dumb. BAM Subwoofers 7 17th January 2002 07:53 AM
