| Chip Amps Amplifiers based on integrated circuits |
hello people,
I did have until yesterday a working JVC stereo, however the CD section failed, so I decided to take it apart, and to my surprise it uses two TDA7294 in its amplifier section. I was just wondering, as I dont like to throw things away, whether to use the Transformer for a LM3886 project or just modify the existing JVC board and use the TDA7294's instead. Has anyone tested the two side by side? What is the cleanest sounding one? Let me know your opinions Cheers Ben |
#2 |
Just one person's opinion: since it's there, tune the h*ll out of it and be surprised what it delivers. IMO it has just about as much potential as the LM38xx chips for clean, musical sound. Give it lots of power supply capacitance, good local bypass and try Carlos' snubbers at the chip end, including snubbers for the compensation cap pins.
#3 |
Well it sounded quite good when it was part of the JVC system. However there appears to be minmal filtering of the PSU, just a couple of 2200uF caps, you recommend to improve this some how? what capacitance should I be looking at ideally?
Cheers ben |
#5 |
nice layout on the board, id use it, just add more caps for the power supply and the snubbers described else where, include the small ceramics across the diode bridge.
it should be easy enough to find the points for speaker conection and input, but my experiance is that intergrated amps need buffering when you take them out of the original system. that isnt to much of a worry as there should be a transformer tap for the cd player that you can use to power the buffer and/or any tone controle. see you soon, steve.. ..
you all laugh because im different, i laugh because youre all the same.. .. |
#6 |
I have some out of an old sharp stereo.
I say, with the ones you found, use em if you got em. I wonder why the TDA7294 isn't as popular as the LM3886? |
| tda 7293 and tda 7294 help | sagarverma | Chip Amps | 82 | 6th November 2011 06:20 PM |
| again in dylema...but to cut down the cost of the woofer amp.TDA 7294 or LM3886? | rhythmdiy | Chip Amps | 9 | 1st November 2007 07:19 PM |
| Amp on TDA 7294 | maris24 | Chip Amps | 4 | 17th November 2006 11:11 AM |
| TDA 7294 PCB - need help :) please | Szaflik | Chip Amps | 3 | 17th December 2004 09:51 AM |
| Page generated in 0.11149 seconds (75.34% PHP - 24.66% MySQL) with 10 queries |
