Old 29th December 2004, 02:19 PM   #1
Selexus is offline Selexus  United Kingdom
Default Gainclone considerations (wrt chassis layout)
Hi everyone,
I'm formulating the final chassis design for my first gainclone (using Brian's boards) and i'd like a little help, please.
Is there a noticable improvement in sound quality when keeping the input wires as short as possible ? With my (basic) understanding of such matters i would have assumed that it was more important to use good chassis connectors (XLR or RCA) and to keep the input routed away from the trafo and PSU, than to be to anal about the actual wire length ?
Also for this 4 channel amp (biamping a single pair of speakers from this one box) would i get better results from using 4 regulator boards and 2 trafo's than 2 boards and 1 larger trafo ?
I'm sure i'll have more questions soon , but if someone could offer an opinion on these i'd be very greatful.
Old 29th December 2004, 02:23 PM   #2
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
the short wire could make the sound better since there is less wire to pick up interference, other than that, I can't think of any other reason.
also, moving the signal wires away from trannys, etc will also improve the sound.
Old 29th December 2004, 02:29 PM   #3
joensd is offline joensd  Germany
As you already mentioned your priority will be to keep PSU noise away from the input.
I´ve made good experiences taking longer input wire but therefore routing it around the PSU circuitry.
But it also should be as short as possible.
If you worry about it you could use an extension for your pot so that it is physically in the back of the amp near the input.
You could also include separate compartments like here
jens
Old 29th December 2004, 02:41 PM   #4
Sherman is offline Sherman  United States
Default Re: Gainclone considerations (wrt chassis layout)
Originally posted by Selexus
Is there a noticable improvement in sound quality when keeping the input wires as short as possible ? With my (basic) understanding of such matters i would have assumed that it was more important to use good chassis connectors (XLR or RCA) and to keep the input routed away from the trafo and PSU, than to be to anal about the actual wire length ...
The issue is one of interference from radio frequencies or electromagnetic sources. Keeping the wire short makes it less of an "antenna" and helps reduce the possibility of interference.
However by routing the wires away from possible RF/EMI sources inside the case and having a metal, preferably aluminum, case to keep RF/EMI from getting in from the outside you can usually build a quiet amp.
Based on experience I like to use shielded wire between the inputs and the amp. Ground the end of the shield to the ground of the jacks, let the other end "float".
--Sherman
Need help with chassis layout bluegti Chip Amps 2 21st December 2008 02:32 AM
Chassis layout? Psychobiker Tubes / Valves 0 12th March 2008 12:12 PM
Chassis layout help Evenharmonics Tubes / Valves 4 4th March 2008 12:52 AM
chassis material considerations Keyoke Chip Amps 20 10th December 2006 07:40 AM
help with chassis layout jarthel Tubes / Valves 5 27th June 2006 05:41 PM
Page generated in 0.11295 seconds (63.09% PHP - 36.91% MySQL) with 10 queries
