| Chip Amps Amplifiers based on integrated circuits |
#21 |
DC on the output arises from the input bias current flowing from the input pins of any opamp-chip. If there is an input resistor to ground, the current which flows out of the pin produces a voltage V = IR on the input pin. You have to do a bit of a balancing act between getting a small enough R value for low input offset, and a high enough R value so that the input pin is somewhat decoupled from the ground at high frequencies.
#22 |
I'm lost, are you saying I need to increase or decrease the value of that resistor?
#23 |
hi sl_1800,
Have you listened to your amp yet? Try some old speakers if you aren't happy with the offset. It sounds to me like you have a good amp to me. 47mV/49mV is nothing to worry about in my opinion. There are hunderds of these BGT NIGC with varying offset. There are a few threads about this topic. If you haven't listened, do it, get used to it, then play with the offset. See if YOU can notice a difference.
Greg Erskine |
#24 |
I agree. 47/49 mV is not all that much.
But try a 620 ohm resistor instead of the 220 ohm resistor.
Best regards Bo |
#25 |
Bo,
The 220 ohm resister you speak of is on the non inverting input. It is just the resister that is in series with the input signal, I don't see how that could make any difference. The resistor between the inverting input and ground is a 680 ohm. |
#26 |
As jacknnj and others tried to point out, there flows a very small current into both the - and the + input. Normally they are of the same amount and they will generate a small voltage over all the resistors on the inputs. When these voltages is not of the same amount, there will be a voltage difference on the + and the - input that is amplified to the output - as you have already noticed.
So a good trick to minimize this effect is to try and make the two small voltages the same, and one way of doing it is to put in a resistor - the 220 ohm - exactly the way BrianGT has done it. It can be proven that its value must be: R = (R-fb1 * R-fb2) / (R-fb1 + R-fb2) In your case: R = (680 * 20000) / (680 + 20000) = 658 ohms So - try it
Best regards Bo |
#27 |
Bo,
Thanks for the explination, I'll give it a try. Your explanation is now starting to make sense. Some of us have to be hit a little harder to see the light.
#28 |
Good thread, especially for me (totally new at this, but wanting to try/learn). Not to take this OT, but how do you measure the offset voltage? I know a bit about what to do if the voltage isn't nearly zero, but I don't really understand how it is measured. I haven't put my kit together yet (any day now
), and appreciate the pointers.
#29 |
sbolin: You need a voltmeter or a multimeter. And you simply measure the voltage (DC) on the output (to the loudspeakers).
Best regards Bo |
#30 |
Bo-
Thanks, seems simple enough. I do have a multimeter, so should be able to carry this out once I assemble my kit. |
| Wrong Voltage / current on BoZ... or Wrong Measuring ? | gionag | Pass Labs | 8 | 14th May 2008 11:24 AM |
| what's wrong with it? | bravesz | Digital Source | 6 | 27th September 2006 08:15 AM |
| something wrong? | spyder6 | Subwoofers | 2 | 21st February 2005 06:58 PM |
| Page generated in 0.11419 seconds (72.06% PHP - 27.94% MySQL) with 10 queries |
