Old 23rd December 2004, 08:17 AM   #1
Default Using Apple iBook transformer with BrianGT kit
I was staring down at the charging unit for my iBook, and in small print it says input 110-240, output 24v. If anyone is interrested it is called the Apple 45W Portable Power Adaptor. There is another one for other ibooks and powerbooks that comes in 90W flavor. Could this unit possibly be a replacement for the transformer in a briangt stereo kit? What other kind of wallplug transformers do you think would work if this is possible?
Old 23rd December 2004, 08:31 AM   #2
r0cket- is offline r0cket-  United States
I doubt it would provide sufficient current (I think they provide about an amp and a half or one and 3/4 @ 24V, which would roughly jive with the 45W rating--still on the small side for a gainclone).
Anyway, those adapters are like $50 a pop, so it'd be cheaper to just build a real supply for the gainclone, and I suspect you'd end up with cleaner power anyway (that, and a supply that won't die every year like the iBook adapters do).
Old 24th December 2004, 10:16 PM   #3
Stocker is offline Stocker  United States
The local Goodwill computer store has loads of power adapters for well under $50... if you don't mind digging, and know what to look for, you could come up with something useful.
Jesus loves you.
Old 25th December 2004, 04:09 AM   #4
neutron7's Avatar
you need + and - voltage. from what you describe it is only +
it would be a pain and not really worth your time to make the converter for it to work. unless you want to run it with single ended, then you will have only 12v or so per "rail" and it will be kind of weak, although it would probbaly work.
for the same pric as that you could get a decent transformer. and parts needed to make a "proper" power supply.
unfortunately most power bricks only have + outputs because most modern digital and computer equipment do not need - rails at all, and even if they do it is at much lower current.
one thing you might look at is power brick for computer subwoofer. i am not sure but i think they probably have + and - output. you should probably put additional filter as well especially if it is a switching supply.
some computer subs are probably digital amps and also only need + supply though so research what you need if you want to go that road..
briangt PSU 1 transformer, 2 PSU, how to? sansbury Chip Amps 30 28th March 2010 08:26 PM
Wiring an Avel Transformer to a BrianGT PS - need help schmalex Chip Amps 9 14th July 2005 07:57 PM
transformer with 3886 (BrianGT Boards) mantisory Chip Amps 2 3rd May 2005 03:59 PM
Transformer and pot for BrianGT kit poeee Chip Amps 15 28th November 2004 01:49 AM
Is this Transformer OK to use with BrianGT's dual mono kit? mattjk Chip Amps 4 22nd October 2004 12:00 PM
Page generated in 0.09860 seconds (77.82% PHP - 22.18% MySQL) with 10 queries
