Is this DC offset problem.
Old 22nd December 2004, 03:38 PM   #1
rs1026 is offline rs1026  India
Default Is this DC offset problem.
Whenever i switch on my lm3886 based gainclone I observe that the papercone of woofer moves forward and then goes back.This is observed even when I switch of the amp.However instead of switching on the amp if I slowly push the powercord into the mains socket I dont observe this movement of the cone.
Is this a DC offset problem?Is this movement common in gain alone amps?Will this movement damage the drivers in the long run?
Old 22nd December 2004, 05:29 PM   #2
Stocker is offline Stocker  United States
This is turn-on thump. solutions are available, do some searching. Usually it is only annoying. If you measure the voltage at your speaker terminals you will be able to tell if you have excessive DC offset.
Jesus loves you.
Old 22nd December 2004, 10:52 PM   #3
thomas997 is offline thomas997  Canada
thomas997's Avatar
Do you have an X type cap across your switch? That might help..
If there is a lot of DC offset the cone will move in a direction, and stay in that direction..
As stocker said, get out the multimeter and measure mV at terminals.
Old 22nd December 2004, 11:08 PM   #4
jaudio is offline jaudio
Thomas997 What do you mean X type cap across yours switch
Old 24th December 2004, 01:02 AM   #5
thomas997's Avatar
Default Re: Is this DC offset problem
Something similar to what is shown on this site:
http://www.sector101.fsnet.co.uk/cyb...inside/switch/
Across the mains switch.
Is this DC offset problem.Hide this!Advertise here!
offset problem intense-tavda Solid State 6 22nd June 2009 09:24 AM
DC offset problem mravlcax Chip Amps 21 30th April 2008 11:08 AM
Another Offset problem... rtate Solid State 6 19th March 2008 12:03 PM
DC-offset problem Bootstrapper Solid State 12 6th October 2007 09:25 AM
A40 offset problem? stickleda Pass Labs 8 1st May 2005 01:56 AM
Copyright ©1999-2017 diyAudio
