| Chip Amps Amplifiers based on integrated circuits |
Hi All,
What are you using as speaker cable for the GC? I have tried copper foil as well as KLOTZ pro cable and both sound very good. Has anyone tried the OTA cable? What exactly is this stuff that has the gaincard users raving with delight? Surely there must be a DIY version?!! Ryan |
#2 |
I'm using Cat5 - one pair for each conductor.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#3 | |
#4 |
I am using Cross-Connected coax cable, a la John Risch design.
For me it is absolutely better choice than Cat5 in any mod. This cable removes any harshness , that was in my system with CAT5. |
#5 | |
What coax are you using to cross-connect? What's the OTA cable? How was that copper foil implemented? Carlos |
#6 |
Carlos, i am using cheapest available coax cable with cooper solid core central wire and aluminium foil and cooper shield, aprox. 0.3$/m
And i am very satisfied for now with these smooth-sounding cross-connected coaxials.But i want to try this configuration of cables with better quality coaxials. Unfortunately there is no available Belden's in my country, and i do not know which cable is good alternative for belden. maybe it is worth to try this cable : Belden H1000 I just dont know what means "soft annealed cooper" ? And how this is suited to audio aplications? |
#7 |
Hi DT,
Belden H1000 you is not good for Jon Risch cross-connected coax for few reason: 1. center inductor is to thick: 2.6mm 2. copper braid is too loose: 50% Regards, --- David |
#8 |
Analog SA,
Is the alphacore foil the same as copper foil that can be brought in small rolls from stained glass outlets? Is the alpha-core foil special in some way? Which specific model do you buy and finally, how do you set-it up? How do you prevent the foils from touching on speaker cable runs? Is it not very fragile? |
#9 |
Hi Ryan
I just copied PD's recipe. No idea what stained glass outlets sell but the Alphacore copper is very pure. For termination i used Cardas at the speaker end and just folded and cut the foil in a spade shape at the amp end. The foil is quite sturdy and although i felt bad about folding it and causing extra stress, it seems to play fine. No idea how to fit banana plugs though... |
#10 |
The OTA cable is a very simple thin solid core cable. You can easily use your favourite thin solid core cables with great results. Note 47 Labs do not recommend twisting the OTA cables as it'll increase the capacitance. This is a very imporant point as some GC, especially ones without the zobels to go into oscilliation. Friend of mine made some cat5 twisted cables and his GC went into oscilliation, sounded like the speaker cone was cracking up.
| F1 or F2 with MIT speaker cables? | roscoeiii | Pass Labs | 1 | 13th July 2009 12:47 AM |
| how much did you pay for speaker cables | peteS | Multi-Way | 43 | 12th March 2006 01:22 PM |
| cables for diy amps, preamps, and speaker cables ... | paulspencer | Solid State | 5 | 3rd August 2004 07:14 AM |
| Speaker cables for gainclone. | protos | Chip Amps | 21 | 18th September 2003 03:54 PM |
| speaker cables | dave k | Multi-Way | 7 | 25th May 2003 08:51 PM |
