| Chip Amps Amplifiers based on integrated circuits |
the circuit below appears in the LM4780 PDF, but is not in the LM3886 descriptor -- pick the RC time constant you want from R1 and C1 to slow the turn on for the LM3886. The current to pin 8 must be greater than or equal to 0.5 ma. Multiple LM3886's can be controlled this way, just multiply the current for each device and pick the resistor combo accordingly.
#2 |
I'm not sure but I think it is on the AN-1192 parts list. under (parts not on schematics). It has two resistor in mute circuit instead of one
#4 |
thanks Pers, i corrected it -- not enough moca java in the system yet!
#5 |
Adding a diode as shown will discharge the Cap immediately,in switch OFF.
Muting the amp @ switch OFF. should be used if higher values of capacitor is used for longer delay...
SivanandBalan |
| Soft Start Necessary? | dtaylo3 | Class D | 2 | 26th December 2008 10:05 AM |
| B+ soft start | Gluca | Tubes / Valves | 2 | 3rd September 2007 02:04 PM |
| Need a soft start? | maxpou | Solid State | 19 | 18th April 2007 10:23 PM |
| Soft start & Soft Switch circuit: can anybody help? | m.parigi | Solid State | 95 | 22nd August 2005 04:32 PM |
| Page generated in 0.07720 seconds (81.70% PHP - 18.30% MySQL) with 11 queries |
