Old 20th December 2004, 09:35 AM   #1
Default Computer controled volume control
My Goal is to create a multi-zone pre-amplifier with the ability to set the volume at each zone via a serial port on a HTPC. Does anyone know of any pre-built PC volume controls or schematics of this type of setup?
I have searched and read about the PGA2310 volume chips, but have not seen them linked to a computer.
Old 20th December 2004, 06:02 PM   #2
your best bet will be to use "digital potentiometers". xilinks, national, and ti all make these. TI's and national's are geared toward audio use. Ti's is a MSSOP (similar to SOIC) package, which may be difficult to solder, but it isn't that hard IMO.
I'm sure you can make a microcontroller-based serial to parallel converter. there are microcontrollers with uarts for serial communications.
if only it could be used for good, not evil...
Old 20th December 2004, 10:16 PM   #3
TwoSpoons's Avatar
All it takes is a wee bit of programming. Not hard at all. Use something like the 'BASIC Stamp' for your controller, the PGA chips for the digital pots, and Visual Basic for the PC application.
Old 20th December 2004, 10:39 PM   #4
hifimaker's Avatar
Here's a great thread from the Pass Labs forum on using PGA volume controls. There not that great. Consider using a PIC controller with relays. This is a much cleaner sounding solution.
XBoSoZ + PGA2310 volume control
Good luck,
-David
Old 21st December 2004, 02:55 AM   #5
Take a look at the evaluation module listed on TI's site here: http://focus.ti.com/docs/toolsw/fold...ga2310evm.html
It seems to be similar to what you want (obviously you'd need to write/modify the program to do what you want - not sure if they give out source code though?).
Old 21st December 2004, 12:23 PM   #6
mcs is offline mcs  Denmark
Some of the control boards I have made have RS-232 ports. So to control a PGA2310 from a PC, all you would need is something like one of my VolControlx boards or the Control2. You can see the schematics on my website.
Best regards,
Mikkel C. Simonsen
My personal electronics website
Remote control kits website
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 08:20 PM
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 04:12 AM
remote control motorised control for volume pot/knob CharlesY Parts 0 25th July 2005 12:12 PM
128 step volume controled by relays roger-k Solid State 4 31st March 2004 09:42 PM
computer controled relay theChris Everything Else 21 29th December 2002 06:47 AM
Page generated in 0.09589 seconds (71.26% PHP - 28.74% MySQL) with 10 queries
