Old 18th December 2004, 06:52 PM   #1
Question Noob Question- Toroidal 25vac (ebay)
I am currently a noob at this chipamp DIY audio stuff but I really want to get into this sort of thing.
Just a couple of questions.
I am planning to purchase and build a Brian GT LM3875 Amplifier Kit (stereo) but having a hard time tracking down a toroidal Transformer. Would the following transformer be compatible w/ this kit?
http://cgi.ebay.com/ws/eBayISAPI.dll...859938899&rd=1
That 25VAC dual secondaries, 600VA runs about 40USD when auction completes.
Is this toroidal worth it?
Is the quality any good?
Are there any places to source toroidals in Canada (spec. Toronto)? ( already checked out plitron, but seems quite expensive)
Thanks for any help.
Old 18th December 2004, 08:52 PM   #2
homer09 is offline homer09  Canada
homer09's Avatar
from what i see in the guide, it seems to be compatible. But the guide says anything over 330VAC is an over kill, this one is 600...
as for quality and such, i have no idea, also pretty new at this and would like a more knowledgable opinion on the matter since im also going to be looking for a toroidal for the same project
the same seller also offers a few different varieties, maybe someone could recommend which is best for a 4 ohm and also an 8 ohm speaker load?
Old 18th December 2004, 09:16 PM   #3
fish4u is offline fish4u  Philippines
dunno about Canada...but try here:
Partsexpress
Apexjr
Old 19th December 2004, 03:06 AM   #4
You could try Eletrosonic- www.e-sonic.com They sell Hammond toroids,and are cheaper than Plitron.There is also a discount if you order 2 or more.Unfortunately,I don't think that they stock many though. Active Components (next door) also sell the Hammonds- www.active123.com
Old 19th December 2004, 08:14 AM   #5
Would the :
Avel-Lindberg Inc
Input: 2 X 120Vac 50-60 Hz
3 3/4" Dia X 1 1/2" Tall
Output: 2 X 28.4V @ 2.67Amps over 150Va
$22.00ea
from Apex JR be compatible with this kit?
APEX JR Toroidal
Actually getting in Canada isn't that important right now, since my relatives are comming over from the US.
Thanks for your help.
Old 19th December 2004, 08:17 AM   #6
pinkmouse's Avatar
Yes.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 21st December 2004, 01:40 AM   #7
Arius is offline Arius  United States
It is not the Chipamp kit that dictates the transformer specs, rather it's the voltage rating of the parts that you use.
National's datasheet and/or design guides have all these info. The gist of it is like so:
1) Pick your desired output power into your desired speaker impedance (usually 8R).
2) Using the National data, figure out the max voltage and current required. E.g. for 30W into 8R, we have 22V@2.8A.
3) Transformer voltage should then be 16V (22/1.4), current should be ~ 6A (for stereo). VA rating = (16X2) X 6 = 200VA.
4) Voltage rating for all other parts should then exceed 22V, e.g. diodes, capacitors.
5) Pick a heatsink(s) suitably rated for your desired output power.
Note that using a dual 16V @ 300VA won't give you more power over a 200VA part. It will if you try to use the Chipamp to drive lower impedance loads (e.g. paralled speakers) but doing that will probably exceed the chip's capability.
eBay TDA7294 kit + Parts Express Buyout 32V CT 200VA Toroidal Power Transformer? IsleOfMan Chip Amps 7 19th February 2009 09:44 AM
15V from 25VAC/36VDC jimbo1968 Power Supplies 6 18th July 2006 08:21 AM
Toroidal winder on Ebay imix500 Swap Meet 0 7th December 2005 05:00 AM
Question- Toroidal 25vac (ebay) whitewind Chip Amps 3 18th December 2004 01:52 PM
Toroidal Transformer on Ebay For Gainclone dine1967 Swap Meet 0 7th May 2004 02:55 PM
Page generated in 0.10548 seconds (78.63% PHP - 21.37% MySQL) with 10 queries
