| Chip Amps Amplifiers based on integrated circuits |
#11 |
btw, if you work the math backwards, a GC on a flat piece of aluminum can be run to a max of 8 watts before the thermal protection will kick in.
#12 | |
#13 | |
It appears that you think I am some Hack.
The diode board is fine as is. It is elevated enough and is secured by small bolts. The only way there would be contact is if the case was dropped and some how was dented in the exact plase that the bridge is. The Xfmr is also adequate. I ran it for hours yesterday at what I consider max volume. Nothing got warm. the case was not even hot to the touch. not even directly where the chip is bolted to the side panel Quote:
#14 |
My appologies for the from the hip defensiveness.
I looked at the photo again and realize that from that angle it appears the board is right down on the metal case. I assure you that it is about a quarter inch above and secured tightly. Good eye I am glad that there are those that keep an eye open for others. |
#15 |
if the low frequency oscillations persist, and it's not 120Hz, try bypassing the 1000uF electrolytics with 10uF electrolytic (can be tantalum or aluminum electrolytic.) the bypass caps should be placed as close to the V+/V- pins as possible.
| Page generated in 0.08277 seconds (61.64% PHP - 38.36% MySQL) with 10 queries |
